Username Post: 454 Troubleshooting        (Topic#365943)
j_ray_actual
Reg: 07-29-21
07-29-21 07:44 AM - Post#2824101
Hi all, new here.
I have a 74-75 model 454 cast block and heads with aluminum intake on an airboat. Carb is 750 CFM Quadrajet that is only a couple of months old. Just installed the following: New plugs, new plug wires, new distirbutor.
I've had problems with the motor at 3-4k rpm. Motor will start fine and idle fine. I can rev throttle fine 1-2k rpm. If I floor it the motor will fall on its face until I let off the throttle, If i keep pressure on throttle motor dies completely. Running a mechanical pump 6psi 80gph. Motor is stock from what I've been told except bored over some. I've been scratching my head for a while with this.
I'm no mechanic but I can turn a wrench. Had timing set with older distributor by mechanic. Just installed new distributor yesterday. Still falling on its face at 3500 rpm.
When I revved up until it died yesterday I pulled a plug and it was wet, so it seems to be getting fuel. I just dont know what else to do.
Ground? Valve springs?
Any help would be much appreciated!
Thanks!
07-29-21 07:54 AM - Post#2824102
    In response to j_ray_actual
Welcome to CT. Is this a marine engine with reverse rotation? HEI ignition? Are you sure the filter in the carb inlet is new and installed in the right direction?
j_ray_actual
Reg: 07-29-21
07-29-21 07:57 AM - Post#2824103
Filter at carb has been removed. HEI distributor with vacuum advance. Regular block and carb. Not marine.
07-29-21 10:02 AM - Post#2824109
Do you mean the element the requires removing the large inlet fitting?
j_ray_actual
Reg: 07-29-21
07-29-21 10:04 AM - Post#2824110
Yes there is a inlet fitting at the front of the carb that had a filter and spring in it. It has been removed.
07-29-21 12:14 PM - Post#2824118
Ok, you have a stock type fuel pump, no electric, your description sounds fuel related, so start at the tank screen if it has one, and move forward, look for any restriction or blockage. Also, rare, but the fuel pump push rod in the block could be worn and shortening the fuel pump stroke, they can look good, but when compared to a new one you can see the difference. Of course this assumes all is good in the carb.
Edited by Shepherd on 07-29-21 12:18 PM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
07-29-21 06:12 PM - Post#2824133
Where did you get a Quadrajet that is only a couple of months old?
07-31-21 09:05 AM - Post#2824201
is this a new problem or did you inherit it?
Execution time: 0.274 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:59 PM
