Username Post: Hei with a Tach        (Topic#365938)
OL55
OL55
Reg: 01-01-08
07-28-21 07:16 PM - Post#2824074
I have an Auto Meter tach on the dash of my 350 with factory hei van. Some time ago I had ignition problems and disconnected it while I figured them out (another post). Running hod now so I reconnected. Shortly after, the engine shut down and refused to start as if it had a bad module. Zip! I disconnected the tach and it started right up!! What is going on? Tia
07-29-21 04:09 AM - Post#2824090
    In response to OL55
Wow! You have a bad gremlin. Electrical shorts are hard to find. Suspect the tach or wiring to tach. Is the tach grounded properly? Is the tach set up for V8 signals? Did it work previously?
'08 GMC Acadia 3.6L SLE
64ss409
Reg: 12-04-02
07-31-21 04:18 AM - Post#2824193
    In response to OL55
I had a similar problem about 15 years ago. Mine turned out to being the tach. It was shorting out the ignition. A new tach fixed my problem.
Ron
1962 SS convertible, 327/250 4 spd
1956 IH pickup, 327
OL55
OL55
Reg: 01-01-08
08-01-21 05:10 AM - Post#2824232
gchemist, Good points. I did find the ground was not grounded. I think the ground was just for the light? Anyway to test?
OL55
OL55
Reg: 01-01-08
08-01-21 05:12 AM - Post#2824233
    In response to 64ss409
64SS409, After you replaced was it good? Are these HEI made for a full time tach? I had no problems for years…
08-01-21 02:55 PM - Post#2824261
    In response to OL55
An HEI can run a tach full time. Mine runs a signal to a digital tachometer. I'll have to go back and read your other post. An electrical power surge can ruin sensitive electronics. My digital voltmeter is not working. It's the second I've put in. Running a 165 amp alternator and dual cooling fans may be causing too much of a power surge.
Execution time: 0.128 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:59 PM
