Username Post: Tilt steering column bearings        (Topic#365929)
kpmunt
Reg: 11-01-04
07-27-21 06:07 PM - Post#2824004
I bought a K10 with an after market steering wheel. I'm planning to put on a stock steering wheel.
The truck has a tilt column.
Is the top bearing and Cancelling cam different between a tilt and non tilt column? There is a tight fit on the top bearing which the regular column doesn't have.
49erman
Loc: So Cal Lower Desert
Reg: 01-02-18
08-16-21 11:59 AM - Post#2825297
    In response to kpmunt
We're not playing guessing games lots of K10's out there, need more info/spec's like what year of truck and what year of tilt column (stock OEM or aftermarket)you know all the right stuff to identify whats being worked on.
Execution time: 0.141 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:30 PM
