Username Post: 2001 power steering pump        (Topic#365926)
chnaus
Loc: Upstate:The Real New York
Reg: 04-18-03
07-27-21 05:18 PM - Post#2824000
I had an issue with my 01 Silverado shortbox
v6. The rack belched out on both ends and at the
same time there was fluid leaking from the back of the pump.
I can replace the rack for about $100.
I have a new pump w/o reservoir from a Caprice.
The gasket set is the same for each pump and the
connections are virtually the same.
The 01 is not my main driver, just for errands and backup.
Are the internals different in these pumps
CH
07-27-21 06:22 PM - Post#2824007
    In response to chnaus
A pump for a standard Saginaw box is different than a pump for rack and pinion. Not sure if the Caprice had r and p.
2plus2
Loc: Mission,BC
Reg: 02-03-05
07-27-21 06:35 PM - Post#2824009
Rockauto lists the same pump for 2wd and 4wd
Different pumps for lower end models vs higher end
I think it has something to do with computer controlled variable assist
OP go look at pumps and click the part number,there will be a list of vehicles that inter change but you have to look at all the pumps to get the full list of vehicles
69 Canadian Pontiac 2+2 Convertible
Factory L48 350 Chev,TH350,PW,PT
99 Silverado RCLB 4.8 NV4500 14BSF 4.10's locker 6" Procomp 35'S
Execution time: 0.118 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:48 PM
