Username Post: 65 Front Swaybar        (Topic#365925)
Motown_mtrhd
Motown_mtrhd
Loc: Grand Blanc Mich
Reg: 12-22-15
07-27-21 05:10 PM - Post#2823998
This has probably been around before but, I would like some ideas on installing a HD front bar on my 65 SS. What have u guys used? And since it runs thru the front frame horns, do the replacements fit the same?
Steve, 65 SS numbers 396,TH400 A/C Lots of power options. 1970 Chevelle, LS-LQ9 Tremec 5 spd,nuthin stock left. Drop Top . 34 Chevy 350 TPI,38 Chevy coupe.
6T5
"4th Year Gold Supporting Member
6T5
Loc: Asheville, NC
Reg: 07-22-17
07-28-21 09:55 AM - Post#2824041
    In response to Motown_mtrhd
I replaced mine with 1 1/8" from POL ( Performance On Line) and yes it went in the same location but had to relocate the bushing brackets over a little bit. Sure made a difference for mine...
...Ed
1965 Impala SS
65_Impala
Reg: 12-29-02
07-28-21 06:00 PM - Post#2824065
I put an Addco 864 1-1/8" sway bar on mine. It makes a big difference in how the car drives. I had to drill 2 new holes for the frame brackets. A lower ball joint on one side has to be separated to get the bar into the frame holes.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
07-29-21 03:35 AM - Post#2824086
    In response to 65_Impala
And installed from the passenger side
65_Impala
Reg: 12-29-02
07-29-21 06:15 PM - Post#2824135
    In response to aghaga
I put mine in from the drivers side. I remember it being in the garage location with a wall on the passenger side and the drivers side open.
AmericanPie
AmericanPie
Loc: Camarillo, CA
Reg: 07-28-01
07-30-21 08:48 PM - Post#2824188
Last year I installed a 1 1/8" Hellwig front sway bar, also from the passenger side. Just had to turn the front wheels left to full-lock, and the old bar came out/new went in surprisingly easy. Very good instructions came with the kit. No fitment problems at all. And it did make a noticeable difference.
Larry
1965 Impala SS 327/PG, Crocus Yellow
Edited by AmericanPie on 07-30-21 08:49 PM. Reason for edit: No reason given.
07-31-21 09:09 AM - Post#2824202
get the biggest one you can get
Motown_mtrhd
Motown_mtrhd
Reg: 12-22-15
08-01-21 06:24 AM - Post#2824237
    In response to AmericanPie
Thanks everyone, I see bars advertised but none of them looked like what my old stocker is, also wondering if one of the lower control arms had to be dropped to get it reinstalled, hence spring compressors, brake lines etc... now what about my old smishey power steering box? Ever buy a tighter one?
Texasray
Texasray
Reg: 11-01-16
08-02-21 01:29 PM - Post#2824320
I put in a AGR 492117 from Summit. Love it!
Sam
65_Impala
Reg: 12-29-02
08-02-21 05:12 PM - Post#2824344
Control arms don't need to be dropped. Worst case pop the lower joint with the spring and shock still installed so you can swing the spindle out of the way. The shock should hold the spring, but if it concerns you keep a floor jack under the end of the arm.
Execution time: 0.121 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:36 PM
