Danchuk
Username Post: Having a MAJOR problem. . .        (Topic#365923)
craig32
Loc: PA
Reg: 08-05-07
07-27-21 03:23 PM - Post#2823989
My 55 has been starting hard all year. (265, points engine, WCFB) I've been driving it for 6 years without issue, and suddenly it's starting hard. I had the carb rebuilt, replaced the coil and resistor and thought maybe the switch was going bad. I put a pushbutton on it, and it seems to fire right up with that when the key doesn't want to work, if I leave the switch ON and use the button. Thought all was good until I tried to drive it to work a couple weeks ago. I got it going and about a half mile out, it starts cutting out, bucking, backfiring, and when I threw in the clutch, it quit. I let it back out and the tires chirp and it starts up again. It seems to run OK in first and second, but as soon as I put it in third (3 speed) it starts bucking again. After I limped it home, I changed the fuel filter, and put a vacuum meter on it, and it's pulling 21 inches consistently at idle. I can wind it into the twilight zone in the garage, but when I take it out again, it dies just like before. I did a compression test and all 8 cylinders are between 170 and 180, all plugs are throwing a fat spark, although one is a little weak. I have NO CLUE what is wrong. Does anyone have any ideas?
66 Impala (almost done!)
56 Stepside shortbed
55 Bel Air sedan
81 Corvette
02 Monte Carlo (bought new)
LtFrankDrebin
LtFrankDrebin
Loc: Coopersburg, PA
Reg: 01-25-01
07-27-21 06:14 PM - Post#2824006
    In response to craig32
So you're saying that you got a different behavior by messing with the ignition switch? Can you bypass the ignition switch altogether (hotwire the car) and see what happens?
'56 210 Townsman wagon 6cyl/3spd OD | '58 Impala Sierra Gold 348
craig32
Loc: PA
Reg: 08-05-07
07-28-21 04:17 AM - Post#2824020
    In response to LtFrankDrebin
No, I didn't mess with the ignition. I have a pushbutton with alligator clips I use for testing. And a hot wire made no difference.
55 Bel Air sedan
81 Corvette
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
07-28-21 06:47 AM - Post#2824032
If you have not changed points (you did not say), condenser, rotor and plugs in six years, my first job would be a full tune-up (distributor cap too). It may not solve your issues but it's due. Verify/set timing after dwell.
If it idles fine, it 's not the switch. The switch does not know if you are driving or sitting.
A fuel pump not putting out sufficient pressure can (just a possibility) cause your issues. There's enough pressure to provide flow at idle, but not under 'load'.
Plug wires? Worth a look.
After you know the ignition is good, then look at carb.
Just trying to be helpful.
Pete
craig32
Loc: PA
Reg: 08-05-07
07-28-21 07:55 AM - Post#2824035
    In response to japete92
Pete
Pete, I put the car on the road 7 years ago this month, and have put 2100 miles on it in that time. The car is garage kept, not driven in inclement weather. I did change all that when I got it on the road, that's all it has on the parts. I put a different carb on it, same issue. A guy told me he had an issue like it and plug wires worked for him. Might have to get a fuel pressure gauge - what should it be?
55 Bel Air sedan
81 Corvette
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
07-28-21 10:21 AM - Post#2824044
"... that's all it has on the parts..."
If you are saying 7 years and 2100 miles is 'all', a full tune up is over due. TIME degrades the contacts.
Fuel pump pressure? From memory, the max for high performance engines was 7 psi and the others were 6 1/2 psi. Recommend check the Shop Manual to verify (but, there's not much difference except at high rpms).
Pete
07-30-21 09:23 PM - Post#2824189
you may have a colapsed ruber fuel line. use fuel injectoin line.
craig32
Loc: PA
Reg: 08-05-07
07-31-21 10:31 AM - Post#2824207
    In response to bobb
I replaced the fuel pump and the rubber line, both appeared to be good, but it seems to have fixed the issue - for now anyways. Thanks everyone for the help.
55 Bel Air sedan
81 Corvette
Execution time: 0.194 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:25 PM
