Username Post: Trying to identify 396 parts by cast numbers.        (Topic#365913)
Yetibob45
Reg: 07-26-21
07-26-21 04:01 PM - Post#2823935
I can find the block and heads but not the intake manifold. I am unsure what to do with the motor now. I was going to try and build a fuel injected play motor for my 89 4x4 suburban. If anyone has any ideas I'm open to suggestions. Thank you.
Block numbers https://ibb.co/jg2NSxb
Heads
https://ibb.co/VVtmr04
Intake
https://ibb.co/WzfnrmN
Edited by Yetibob45 on 07-26-21 04:02 PM. Reason for edit: No reason given.
elcamino
elcamino
Reg: 03-30-00
07-27-21 06:30 AM - Post#2823963
    In response to Yetibob45
T0106IN
Tonawanda Engine Plant
01 - Month of Jan
06 - Day of month
IN - Engine Suffix code also know as Broadcast Code
IN - 1966-67 396-325hp TH Trans
C120657 is vin derivative also known as "CON VIN"
C - Chevrolet Truck Division Code, Pass car line used a 1 to denote Chevrolet.
120657 - Last 6 digits of VIN
2021 GMC Sierra Denali CC 6.2L / 10-sp
2018 Polaris RZR S 900 EPS
paulo57509
Loc: CA
Reg: 07-18-00
07-27-21 11:39 AM - Post#2823977
Heads
Intake
It's kind of vague on what you're asking. You already know what the engine was when it was first built. A lot can happen in 43 years.
At this point, I think you need to determine if it's a rebuildable core.
What kind of FI system are you thinking of bolting on?
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Execution time: 0.149 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:31 AM
