Username Post: Trunk lock turns but won’t open        (Topic#365901)
frankthetank
Loc: Lodi California
Reg: 02-22-11
07-25-21 09:54 AM - Post#2823866
I had just got done installing a new trunk weatherstrip seal on the 63 impala. I let it sit for an hour then closed the trunk lid only to realize the key turns the lock but it won’t pop open.
I think it has something to do with the vacuum trunk coupler possibly not being on correct. To top it off the vacuum hose is disconnected so I can’t open it that way.
Is there any other possible way to open it beside drilling out the lock?
1963 Chevrolet impala sport coupe
2006 Chevrolet silverado crew cab 2wd
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
07-25-21 11:23 AM - Post#2823871
    In response to frankthetank
One may enter the truck from the back seat. Remove bottom and back 'cushions' to gain access. Crawl in and 'unlatch' the truck from the inside.
But, before crawling in, try lifting the lid simultaneously with unlocking.
I have no experience with the vacuum trunk release option, but on the cars w/o it, the tension in the 'bar' springs 'raises' the lid upon unlocking'. It would surprise me (and very well may) if there is enough 'force' from the vacuum to raise the lid.
Hope this helps.
Pete
Edited by japete92 on 07-25-21 11:39 AM. Reason for edit: No reason given.
frankthetank
Reg: 02-22-11
07-25-21 11:52 AM - Post#2823872
    In response to japete92
Thank you Pete I’m going to go out there and try after breakfast.
Edited by frankthetank on 07-25-21 11:52 AM. Reason for edit: No reason given.
Mercedes
Reg: 07-09-18
07-25-21 02:13 PM - Post#2823879
Over time, the rod that connects the tumbler to the lock assembly bends from use. Pull it apart and look at the flat piece of steel.
My guess is that by twisting it back in shape, you'll have better travel when turning the key.
that's exactly how I fixed mine
frankthetank
Reg: 02-22-11
07-25-21 03:35 PM - Post#2823884
    In response to Mercedes
I got the rear seat out of the way and the board that I have my amplifiers mounted to but no way all 295 pounds of me is fitting in there. Right now I’m just trying to find something long enough with enough of an angle to try to pull the clip out that holds the lock cylinder in place against the trunk lid.
frankthetank
Reg: 02-22-11
07-25-21 04:56 PM - Post#2823887
Got it. I had no choice left but to drill out the lock. I had a one key kit for the whole car now I’ll have a separate trunk key.
Oh well it’s open. Now the joy of trying to set my amplifiers back in place. Extra joy being 6’4” tall crammed into the trunk
Edited by frankthetank on 07-25-21 04:57 PM. Reason for edit: No reason given.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
07-25-21 05:29 PM - Post#2823888
A good locksmith can rekey a different trunk lock to match your other keys by giving him two locks ( a trunk lock & one from the doors or ignition. )
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
junky
Loc: Northeast CT
Reg: 06-27-10
07-25-21 06:20 PM - Post#2823889
    In response to pvs409
Pull the ignition cylinder, and give the locksmith the key number that is stamped on the side of the barrel. If there is no number, then give him an original key, and he can "read" the peaks and valleys to determine the correct wafers to install in the new trunk lock. Best to find an old time locksmith company, because they will have the most experience dealing with automobile locks of 50 years ago.
What was the cause of the lock mechanism not releasing?
frankthetank
Reg: 02-22-11
07-25-21 06:22 PM - Post#2823890
    In response to junky
Thanks Paul & junky good advice
Site Ambassador
07-25-21 07:18 PM - Post#2823895
Too late now, but you may have had to push down on the trunk lid and turn the key. Since you have a new weatherstrip it may have had too much pressure pushing up to make the latch release easily. Keep that in mind when you put in the new lock cylinder. The trunk lid may not want to open again once you put in the new lock cylinder.
1957 Cameo Carrier
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
07-26-21 05:02 PM - Post#2823943
    In response to wagonman100
Before you pull another lock (door or ignition) call a few reputable locksmiths and se whether they can rekey it from your key. Most good locksmiths can gage the notches on the key and match to tumble 'size' as long as they can get the correct tumblers for your lock
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
nicholes
nicholes
Reg: 11-11-20
08-12-21 03:57 AM - Post#2824986
this may sound dumb but most of the time the linkage fell off in side the lock.
junky
Loc: Northeast CT
Reg: 06-27-10
08-12-21 03:57 PM - Post#2825033
    In response to docjns1
Get a trunk monkey. Then all you will need to do is say Open Sesame.
https://www.youtube.com/watch?v=XW8iAVwt_Yc
327
Loc: Ontario , Canada
Reg: 02-09-21
08-13-21 04:23 AM - Post#2825060
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
08-13-21 07:44 PM - Post#2825107
It sounds like you are getting some good advice. Don't get in a hurry. I would try pushing down on the trunk first. Next, try to find a young small friend to crawl in the trunk. A locksmith is also a good idea, you would be surprised how fast they work. The drill is the last resort.
Dave
junky
Loc: Northeast CT
Reg: 06-27-10
08-14-21 06:46 PM - Post#2825162
    In response to dgstarr
Dave
Did you read what he wrote????
07-25-21 10:18 PM - Post#2823895
Execution time: 0.258 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:18 PM
