Username Post: Edelbrock heat insulator gasket        (Topic#365897)
Mlcdc1
Reg: 07-11-20
07-24-21 12:08 PM - Post#2823820
Installed new Edelbrock 1906 AVS2 with adaptor plate (#2696) on a stock 350 in 1977GMC pickup. Looking for recommendations on spacer to decrease heat affecting the carb. And, would the spacer be placed between the carb and adaptor or between the adaptor and the manifold. I’ll appreciate any recommendations-thanks.
Edited by Mlcdc1 on 07-25-21 03:21 AM. Reason for edit: No reason given.
07-25-21 02:58 AM - Post#2823850
    In response to Mlcdc1
An full open spacer is not recommended. My 1406 Edelbrock is bolted to a four hole swirl spacer.
Part number: Edelbrock 2696. It's a little thick. Our trucks do have plenty of room. Do you plan to keep the stock air cleaner intake? Max size under the hood is a 4" filter with an adapter.
'08 GMC Acadia 3.6L SLE
Execution time: 0.122 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:57 PM
