Username Post: BREAK LEAK        (Topic#365888)
Eds66
Reg: 07-31-16
07-23-21 05:27 AM - Post#2823748
I HAVE A 1966 IMPALA IVE BEEN WORK ON FOREVER LIFE HAS BEEN THE WAY SO I WORK ON IT WHEN I CAN I HAVE ONE BREAK CYNLENDER AFT LEFT CHANGED IT TWICE BUT IT KEEPS LEAKING HAS ANYONE HAD THIS PROBLUM
space66
space66
Loc: Montreal,Qc
Reg: 06-01-16
07-23-21 06:49 AM - Post#2823755
    In response to Eds66
where is it leaking from , piston, line, bleeder even new rebuilds can be defected ...
My first car: 1970 Olds, 442,455 (1981-82)
My last car : 1966 Chev. Impala convertible,396 (1984-2020)
current car: Can't afford them anymore ...
Eds66
Reg: 07-31-16
07-23-21 09:54 AM - Post#2823763
    In response to space66
FROM THE LINE IN PORT
Anonymous
07-23-21 12:30 PM - Post#2823772
Because you have used 2 different wheel cylinders, and the odds they are both bad at the line connection seems odd, I would look closely at the double flare on the brake line to see if there is any damage or imperfections. If so, make a new line to the T on the differential.
Site Ambassador
07-23-21 01:02 PM - Post#2823774
    In response to Impalas4ever
I agree. Look at the connection in the wheel cylinder to see if the mating surface for the flare looks good too. I replaced a brake line on my truck back in October. I bent the line, cut it to length, formed a new flare on the end the connected to the front rubber hose. Worked perfectly. Then about a month ago it started leaking. I took it apart, cleaned everything and checked the flare. Everything looked great but I could not get it to stop leaking. I cut the line a bit shorter and reflared it and it stopped leaking. So even if the flare looks good it might not seal for some reason. Even cleaned up with no fluid coming out of it the flare still looked perfect. No cracks in the line either.
1957 Cameo Carrier
07-23-21 09:05 PM - Post#2823790
is it even a double flare? some butcher or lack of knowledge person mayhave replaced it prior to this.
Execution time: 0.152 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:02 PM
