Username Post: Water pump        (Topic#365886)
z28summit
Reg: 06-11-14
07-22-21 06:57 AM - Post#2823675
Anyone know of a place selling a short shaft water pump and pulley setup for the 235's?
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
07-22-21 08:26 AM - Post#2823683
    In response to z28summit
The Filling Station, Chevys of the Forties...
1952 Styleline Fourdoor, 62 235 Cast Iron Power-glide.
Six in a Row, makes Her go
z28summit
Reg: 06-11-14
07-22-21 09:32 AM - Post#2823688
    In response to gcrkfrd
Both on wait lists...
mark50
Loc: SF, CA
Reg: 05-10-04
07-22-21 02:41 PM - Post#2823706
If you have the cone shaped pulley you can order a regular 235 water pump and push the pulley mounting flange down the shaft with a vice and a couple of sockets. I did this about a month ago. Then just cut off the extra shaft. I'm sure the pulley is available separately too and overall it's about half of what the main suppliers charge.
z28summit
Reg: 06-11-14
07-25-21 07:20 PM - Post#2823896
    In response to mark50
How far did you push it through? Ya I'd have to source a pulley
mark50
Loc: SF, CA
Reg: 05-10-04
07-26-21 10:36 AM - Post#2823920
I don't remember how much I moved it down, but at least an inch. I just measured the old pump that I replaced, and it's 4-1/4" from the pump flange mounting face to the top of the pulley flange face. There's 7/16" between the pump shaft casting and the bottom of the pulley flange. Hope that makes sense!
z28summit
Reg: 06-11-14
07-27-21 04:17 AM - Post#2823957
Great, thanks for checking that.
Execution time: 0.122 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:03 PM
