Username Post: 4 spd on the column?'s        (Topic#365872)
49erman
Loc: So Cal Lower Desert
Reg: 01-02-18
07-21-21 09:47 AM - Post#2823623
I think I have heard that it is possible to have a 4 spd. trans & linkage hooked up to the 3 spd. (3ott) columns linkage trucks (mine is 68 C10)along with some kind of (pto) type of cable attachment for the reverse lever to engage it in reverse while the column shifter is in neutral.
I appreciate any help or links.
Thanks;49erman
07-21-21 08:26 PM - Post#2823661
    In response to 49erman
can
49erman
Reg: 01-02-18
07-22-21 09:40 AM - Post#2823689
    In response to bobb
  • bobb Said:
can
So bobb do you have anymore to add like DIY info or any links, don't know where your going with your reply "can"?
07-23-21 07:00 AM - Post#2823756
thinking about the concept i believe i would be able to do it because it sounds very doable. as for where to go, i cant help you there, you would have to be in my town.
49erman
Reg: 01-02-18
07-23-21 05:38 PM - Post#2823780
    In response to bobb
Not looking for your physical help (not traveling to your town either) type of deal, looking for tried and true methods info on someone having actually doing it.
Execution time: 0.464 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:02 AM
