Username Post: bondo        (Topic#365868)
07-21-21 07:23 AM - Post#2823615
why does bondo harden with a sticky surface? how can i avoid this?
paulo57509
Loc: CA
Reg: 07-18-00
07-21-21 04:39 PM - Post#2823652
    In response to bobb
I've wondered the same thing. Must have something to do with the mix ratio of filler to hardener. Even though the ratio is supposed to be 50:1 (filler:hardener) it's mostly an eyeball estimate.
I've found that once you start sanding through the tacky surface layer, there's hard filler underneath.
Someone once told me not to mix on cardboard or other porous material because it will absorb some of the filler/hardener and throw off the ratio.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
07-21-21 08:13 PM - Post#2823660
    In response to paulo57509
as i understand it. bondo is made of resin and talcum powder. so the porus material will suck up all the resin. if i mix it hot its not as bad, but working time is like 1 minute or less.
Mel Foye
Mel Foye
Reg: 09-29-00
07-22-21 02:57 PM - Post#2823707
Several body classes said nothing porous. I use a rear side glass from a VW. Cleans up easy.
Site Ambassador
07-22-21 07:21 PM - Post#2823726
    In response to Mel Foye
I’ve mixed body filler on cardboard for decades with no adverse effects. Telling people not to use cardboard was mainly so that the filler didn’t pick up contaminates from the cardboard.
As for filler having a sticky surface, it can be from many factors. Hardener to filler ratio, ambient temperature, and humidity can all play a part. And yes, you can usually knock off the very top, sticky layer, and get to hardened filler.
1957 Cameo Carrier
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
07-24-21 05:37 PM - Post#2823835
    In response to wagonman100
... also using quality body filler (usually not containing the letters b, o, n, d, o) helps.
Belair-o
Reg: 03-26-07
07-27-21 05:24 AM - Post#2823959
    In response to kool53
So what do you consider quality fillers, and what is wrong with Bondo?
Execution time: 0.074 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:01 AM
