Username Post: Dome light removal ?        (Topic#365864)
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
07-20-21 03:02 PM - Post#2823583
Got most everything off just can't get the wiring and plug separated from the bulb socket ? any tips.
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
07-22-21 06:29 PM - Post#2823723
    In response to 2D51STYDLX
I looked the the dome light in my coupe. Boy! That is a bugger isn't it? There are two tabs on either side that, if straightened would allow the socket to go forward...I think. The only other way, is to force the wires out through the socket and unsolder the button on the end. Once the buttons are removed, the wires should pull out of the socket and free up the base of the light for removal. Be careful not to loose the springs! The wires on mine are very stiff, as they have been subjected to 60 + years of summer sun light...in other words...baked!
Attachment: Dome_Light_Socket.jpeg (2.4 MB) 3 View(s)
1951 Fleetline Preservation
2D51STYDLX
2D51STYDLX
Reg: 03-03-11
07-23-21 05:17 AM - Post#2823745
    In response to RAM_51
Thank you sir, my main problem is the on/off switch being stuck on, think ill do the best i can just hanging by the wires, my wires are also brittle, Nebraska car.
Roger
John Prine
RAM_51
RAM_51
Reg: 12-28-02
07-23-21 06:19 AM - Post#2823751
My headliner had been removed. So my resolution would be to splice in fresh wires somewhere along the exposed wires from where they come from the main harness going over the door and window.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
07-23-21 08:47 AM - Post#2823761
I bought a new socket at Auto Supply and robbed the wires resin disc, and spring. Used a tubing brush to clean the socket. Replaced the guts.
Side note-My neighbors asked me why my place smelled like PB Blaster.
1952 Styleline Fourdoor, 62 235 Cast Iron Power-glide.
Six in a Row, makes Her go
Execution time: 0.124 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:56 PM
