Username Post: 1985 chevy scottdale overheated        (Topic#365861)
Eds66
Reg: 07-31-16
07-20-21 09:37 AM - Post#2823569
I have a 1985 scottdale it overheated now it runs ruf and then stalls
07-20-21 12:18 PM - Post#2823576
    In response to Eds66
Welcome to the site. Have you pulled the spark plugs to check for coolant? Take off the radiator cap when it's cold. Crank it. Do air bubbles come through the radiator? Are the spark plug wires okay? We need more information to help. What caused the overheating?
'08 GMC Acadia 3.6L SLE
Eds66
Reg: 07-31-16
07-21-21 04:23 AM - Post#2823606
the radiator started leaking and over heated
07-21-21 03:40 PM - Post#2823650
How's the oil level? What kind of oil do you use? Can you take compression on it? How long did it run hot? The most common failure is head gaskets. Simple enough to replace but heads must be checked. Compression must be checked before removing the heads.
Execution time: 0.13 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:48 AM
