Username Post: 1993 suburban 2500 454        (Topic#365812)
Rusde1974
Reg: 07-15-21
07-15-21 06:01 PM - Post#2823271
Start it up idles like has a huge cam in it if it idles at all. To get going have to lightly lightly give it gas and maybe it will go. Once going down highway it will smoothen out but if u stop for more than a few seconds the idle will drop and idle like a cam in it again. And if u shut it off it does it all over again. Also going down interstate all of a sudden itfeels like u tapped the brakes and then the service engine soon light will come on and if I pump it slowly 4 or 5 times it will all of a sudden jetk forward and light will go off and it will spit sputter for a cpl seconds then smooth out again. Ive replaced MAF sensor the IAC and the throttle position sensor and fuel filter and even cut off muffler... New plugs and wires also. Any help be much appreciated im ready to see if tnt will fix it lol
Edited by Rusde1974 on 07-15-21 06:04 PM. Reason for edit: No reason given.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
07-15-21 10:16 PM - Post#2823290
    In response to Rusde1974
Howdy and welcome!
Have you pulled the trouble codes?
Also, what’s your fuel pressure?
Greg
‘01 Silverado 2500HD 8.1/Allison 1000 Xcab/LB
'00 Explorer XLT 4.0 SOHC V6 Auto
'95 K1500 Z71 EC Short Step 5.7L+0.040/NV3500 SOLD
Rusde1974
Reg: 07-15-21
07-15-21 10:50 PM - Post#2823297
    In response to CowboyTrukr
I did the jumper wire thing and it just keeps flashing the number 12 and im not sure on the fuel pressure dont have the tool to check it
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
07-16-21 06:40 AM - Post#2823307
Ok. No codes is good and bad.
If you can get to a chain parts store to get the TBI fuel test kit on loan, I’d get a test on the fuel pump.
Just a clarifying question: You replaced the manifold absolute pressure module and not the MAF, right?
Greg
Rusde1974
Reg: 07-15-21
07-16-21 05:51 PM - Post#2823340
Yes I replaced the MAP sensor I apologize if I said MAF cuz it apparently doesnt have one of those correct?
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
07-17-21 12:38 PM - Post#2823377
That’s correct. The MAF came with the Vortec L31 engine in 1996.
Greg
Chevytech
Chevytech
Reg: 04-25-04
07-17-21 06:13 PM - Post#2823392
It will flash out code 12 three times before it moves on to the next code.
Rusde1974
Reg: 07-15-21
07-19-21 09:39 PM - Post#2823540
    In response to Chevytech
Yea I know but thats all it flashes is 12 over n over
Chevytech
Chevytech
Reg: 04-25-04
07-20-21 04:56 AM - Post#2823552
It sounds like it is running to rich. Test the coolant temp sensor that is used to determine how much fuel to inject.
Specifications are the same for small block and big block engines.
Specifications in this thread:
Rusde1974
Reg: 07-15-21
07-22-21 07:47 PM - Post#2823730
How can u test them? Sorry im an idiot when it comes to that stuff
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
07-22-21 09:49 PM - Post#2823733
Do you have access to a volt meter?
Greg
Rusde1974
Reg: 07-15-21
07-30-21 03:01 PM - Post#2824176
Yes but not really proficient in using them? Would a computer make it do what ots doin?
udidwht
Reg: 08-08-17
08-04-21 06:24 PM - Post#2824515
Sounds very much like a bad CTS (cooling temp sensor) When they fail they usually fail in the 'full rich' mode -40 degreesF.
Also and I don't say this lightly...
Only replace part/s with...AC Delco part/s. Anything else and it will not meet the calibrated standard that a Delco meets.
1994 Fleetwood Southwind Storm 28ft
P-30 chassis 7.4L 454 TBI 58,306 miles and counting....as of 05/28/19
VIN# 1GBJP37N4R3314754
Rusde1974
Reg: 07-15-21
08-12-21 02:36 PM - Post#2825026
    In response to udidwht
Changed coolant temp sensor and still does same thing
Chevytech
Chevytech
Reg: 04-25-04
08-13-21 05:02 AM - Post#2825065
Another possibility is an IAC (Idle Air Control) issue.
The engine may be “loading up” if the the system has lost control of the idle.
NOTE: The IAC is different for big blocks (your 454).
Sabino
Reg: 07-16-05
08-13-21 07:49 AM - Post#2825074
I’d check fuel pressure as suggested above
65 Belair 350
68 Camaro 327
93 Suburban 5.7L TBI
Execution time: 0.129 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:58 PM
