Username Post: '68 Chevelle 3 sp. OD trans ?        (Topic#365632)
rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
06-27-21 03:58 PM - Post#2822201
how do you tell the difference between a Saginaw and Muncie 3 speed?
where there different gear ratios within the same mfg.? this one is very close between 2nd and High.
any other help will be appreciated.
thanks Rod in AZ
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
06-29-21 04:37 PM - Post#2822330
    In response to rod
You should see an ID # stamped on the case near the lower rear corner of the side cover that will indicate manufacturer and date. As for ratios, usually the splined input shaft will have rings/grooves cut around the shaft to indicate the ratios. I've seen several charts with different ratios for the same trannys so take that w/a grain of salt.
Attachment: 20200305_214514.jpg (870.5 KB) 2 View(s)
Attachment: 20200512_202614.jpg (2.71 MB) 4 View(s)
Attachment: SAGINAW_3_SPD_RATIOS.jpg (11.17 KB) 2 View(s)
Attachment: trans_ID.jpg (112.18 KB) 8 View(s)
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
rod
Loc: kingman,az
Reg: 04-29-00
06-30-21 07:16 PM - Post#2822416
    In response to docjns1
Steve, what a great job you did. I cant wait till tomorrow to check the mfg. wont know the ratio till I pull it. much later after the AZ heat goes away.
big thanks. Rod in AZ
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
07-01-21 03:56 PM - Post#2822464
    In response to rod
my pleasure!
Steve
327 / 300 L74
M11 3 on the tree
Execution time: 0.095 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:43 AM
