Username Post: New Brake Lines = Locked up Front Discs        (Topic#365608)
vabeach56wagon
Loc: Chesapeake,VA,
Reg: 04-22-02
06-24-21 07:22 PM - Post#2822061
Replaced every inch of brake lines in our '69 Z28.
Filled master reservoirs....started bleeding process at right rear....
No flow there.
Front discs are locked up with bleeder valve at right rear open.
We also replaced the brake/clutch pedal assembly under the dash.
Made no change to the brake rod length. Had approximately 3/4" free play.
Is there a step I've missed. Tomorrow we will go through system and crack fittings to see where we have fluid flowing.
paul
Original builder of the Gobstomper - '56 210 9 passenger wagon now in other's hands. Current Ride is '69 X33D80 Z28 Camaro
Edited by vabeach56wagon on 06-24-21 07:53 PM. Reason for edit: No reason given.
Mel Foye
Mel Foye
Reg: 09-29-00
06-26-21 11:23 AM - Post#2822131
    In response to vabeach56wagon
From a former 69 Z-28 owner to a current owner.
Under the MC there is a block with a small rod that fits in a notch on a sliding metal dowel. If the dowel is not centered you will not be able to bleed one end of the car or the other. Need to hold the rod down while bleeding.
I am leaning toward the fronts not releasing answer being in the MC.
Sorry late and not much help. Mel
It Was On Fire When I Laid Down.
vabeach56wagon
Loc: Chesapeake,VA,
Reg: 04-22-02
06-29-21 05:24 PM - Post#2822329
    In response to Mel Foye
Mel: Is that the button at the rear with the rubber boot over it?
I've kept it depressed while attempting to bleed both rears and fronts.
I loosened the master/booster at firewall, released the button, cracked the fittings at the front brakes and, voila', the pads backed off...
Retightened the master and bleeders and still have free wheels.
I'll keep working on it to get the rears bled, then go back to the front (RR - LR - RF - LF)... been doing that dance for more than 50 years!!!
paul
Mel Foye
Mel Foye
Reg: 09-29-00
06-29-21 08:57 PM - Post#2822343
Yes that was the right spot to push down. From now on I will go to the 57 thread to watch outcome. Mel
All times are (GMT -0800) Pacific. Current time is 05:08 AM
