Username Post: Interior Door Handle spins        (Topic#365601)
dtreat
Loc: Virginia
Reg: 10-25-20
06-23-21 05:12 PM - Post#2822028
Does anyone have a picture of the interior mechanism the handle attaches to. When mine is installed with the clip, it doesn't stay tight and the gear doesn't catch. I can push it on slightly farther and it'll work, but then comes loose again. Locking pin keeps it from coming off.
Here is a pic of mine with door panel off. Little curious about the grooves, that isn't in the window one.
Not sure what to do to keep it tight.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
06-23-21 07:27 PM - Post#2822035
    In response to dtreat
Sounds like the splines are wore out on your window handle. you're going need a new one.
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
06-24-21 01:47 AM - Post#2822037
    In response to 55 Shaker
55 Shaker is right. Closeup of the handle in your top picture appears to show worn splines in the door handle. New ones are available from many sources- Chevs of the 40s, Filling Station, etc.
Dean50
dtreat
Loc: Virginia
Reg: 10-25-20
06-24-21 05:10 PM - Post#2822059
Thanks much. For anyone in the future, the portion attached to the door is called the door latch relay. Can't find that part, hopefully a new handle is all I need.
flatout
flatout
Loc: Idaho
Reg: 12-15-01
06-24-21 06:24 PM - Post#2822062
The splines on the door latch relay look good. As stated above, it's probably the handle splines that are worn out. If you push the handle on the relay with out the spring and without the C clip it should engage it snugly.
Edited by flatout on 06-24-21 06:26 PM. Reason for edit: No reason given.
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
06-25-21 01:34 AM - Post#2822067
Your Chevy looks pretty clean going by your photo of the door.
Got any more pics? Have fun with it.
Dean50
bobt
Loc: colonial heights va
Reg: 06-28-14
06-25-21 01:35 AM - Post#2822068
    In response to flatout
The handle is worn out.The drivers side gets used more so replace it with one of the rear handles until you get a replacement
06-25-21 05:07 AM - Post#2822072
    In response to bobt
The handles are pot metal and wear out from time to time.
dtreat
Loc: Virginia
Reg: 10-25-20
06-26-21 03:56 AM - Post#2822120
    In response to Dean50
This is my "barn find". Was my grandfather's. Been sitting in my dad's barn for at least 30 years, closer to 40. Right before he passed last summer he asked me to take it and do what he always meant to, make her run. All original. 216 with 3 on the tree. Still 6v. I've been tinkering with it since. New brake system, engine wouldn't turn at first but finally worked it out, generator, lists of small electrical issues, whitewalls, etc. Had the maiden run down the street and back, well almost all the way back. Towed her back the last 1/4 mile. I live on a hill and I think not enough gas in the tank when I was coming up that hill. Started right up in the garage. I'm excited. I'll take some more pics and post, but here's one.
06-26-21 04:27 PM - Post#2822147
Great looking 50. Great to keep it in the family. My folks had a 50 hardtop in the 50's.
29-41, 42-48, 49-54 Moderator
rickityfifty
rickityfifty
Loc: south australia
Reg: 10-07-14
06-26-21 04:55 PM - Post#2822150
That lack of fuel problem is probably the fuel pump.
When I was bringing mine home into the Adelaide Hills it was running really nicely until it had to go more than a few hundred yards uphill. If I could have finished the journey in reverse it would have been fine.
Good luck with it and enjoy.
1952 Chevy Business Coupe
1967 Chevy C10 Panel Truck SOLD
2005 Holden Rodeo Pickup (Isuzu)
1923 Tbucket SOLD
2002 Volvo C70 convertible (bought cheaply as a bit of a joke but it does go well)
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
06-26-21 05:29 PM - Post#2822152
Very cool! You're on your way. Welcome
Dean50
dtreat
Loc: Virginia
Reg: 10-25-20
06-27-21 09:24 AM - Post#2822178
    In response to rickityfifty
Maybe I'll stop it on the hill on purpose and see. Now that I know I can always back down the hill and start her.
flatout
flatout
Loc: Idaho
Reg: 12-15-01
06-28-21 04:09 PM - Post#2822274
Nice looking car! That will clean up nicely.
Execution time: 1.185 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:34 PM
