Username Post: rear end brake question for a 87 Camaro        (Topic#365585)
jbander
Reg: 07-19-19
06-22-21 08:31 AM - Post#2821938
Do you need a proportioning valve at all when you convert from drum to disk on the rear of a 87 Camaro, making it disk brakes front and back.
Can you hard line the rear disks or should I put rubber hose at the end . I can use the existing line if I can use stainless all the way if I don't need a hose on the end.
Texasray
Texasray
Reg: 11-01-16
06-26-21 08:25 AM - Post#2822127
    In response to jbander
Yes you need a proportioning valve for a Disc/Disc car. Yes you need to run a short rubber line if the calipers float or if you want easy R&R for service.
Sam
Execution time: 0.082 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:12 AM
