Username Post: steering drag link        (Topic#365566)
grechevy
grechevy
Loc: delaware
Reg: 01-25-09
06-20-21 06:48 AM - Post#2821841
will replaceing steering drag link require alignment if tie rod sleeves are not loosened.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
06-21-21 09:29 AM - Post#2821896
    In response to grechevy
More than likely
Joeyd59
Gold Supporting Member
Joeyd59
Loc: New Jersey
Reg: 02-11-12
06-21-21 11:56 AM - Post#2821906
    In response to aghaga
It'd be wise to have it checked because you don't know some of the variances with replacement parts anymore.I've seen this from to time.
bigbowtielover
bigbowtielover
Loc: Surrey British Columbia
Reg: 09-01-13
06-26-21 04:06 PM - Post#2822142
Most of the time the new part is not exactly the same as original and alignment needs checking. Good rule of thumb is that anytime you change any steering parts you should have it aligned or checked.
Execution time: 1.468 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:09 PM
