Username Post: 52 Brake Adjustment        (Topic#365560)
52_styleline_deluxe
52_styleline_deluxe
Loc: Boise, ID
Reg: 10-16-02
06-19-21 11:38 AM - Post#2821807
Recently i replaced all wheel cylinders on my 52 and adjusted brakes according to shop manual. "Turn screw until light uniform drag is felt. Back off 14 notches".
This seem to give too much petal movement before shoes firmly contact the drum.
For over 70 years I have adjusted brakes according to an old mechanics advice.
" Tighten brake adjustment screw until the shoes are firm against drum. Back off until a very slight resistance is felt on the high spots"
Have I been doing it wrong for all these years.
Which method works best for you.
Ron Rogers
apix17
Loc: San Francisco Area
Reg: 12-22-07
06-19-21 12:57 PM - Post#2821811
    In response to 52_styleline_deluxe
When I was a kid working in a gas station they taught me to adjust them just as you described you have been doing it for years. I tighten them until the wheel locks and back off a few notches until the shoes drag a bit as you rotate the wheel. I always have a nice high pedal and never have had a problem either with the customers cars back then or my own cars.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
06-19-21 01:16 PM - Post#2821812
You didn't mention if you also adjusted the toe board clearance.
1951 Fleetline Preservation
52_styleline_deluxe
52_styleline_deluxe
Loc: Boise, ID
Reg: 10-16-02
06-19-21 02:40 PM - Post#2821815
    In response to RAM_51
No did not adjust toe board clearance
Ron Rogers
bobt
Loc: colonial heights va
Reg: 06-28-14
06-20-21 02:20 AM - Post#2821829
I leave some drag on all four wheels. Make sure the drag is even on the front two wheels so it doesn't pull the steering when you brake. I know a lot of purist will disagree but I get very long life on my my shoes and have plenty of petal. The rear ones SHOULD self adjust when backing up. bobt
Execution time: 0.769 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:40 PM
