Username Post: 64 impala hood hinge sound        (Topic#365557)
USCGMK1
Loc: San Juan, Puerto Rico
Reg: 07-24-15
06-19-21 08:54 AM - Post#2821798
Looking for any help with what is causing a springing sound coming from my drivers side hood hinge. It is an original hood hinge and its been cleaned up and painted. Its been working fine for the past 5 years, but now it makes a really loud sound when opening, closing is fine and it stays up like it should.. I couldn’t find anything on the internet about sounds coming from there so any help is welcome. Thanks I’m advance.
kingkreeton
kingkreeton
Loc: Nashville TN
Reg: 04-15-11
06-20-21 04:54 AM - Post#2821831
    In response to USCGMK1
You can always try some white lithium grease. It doesn’t look great after it’s applied but works more often than not.
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
junky
Loc: Northeast CT
Reg: 06-27-10
06-20-21 04:18 PM - Post#2821867
HD spray silicone also might work, however, it is most likely that the hinge pins (rivets) are worn, and the hinges need to be rebuilt.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
06-21-21 05:49 AM - Post#2821885
    In response to junky
try some garage door spring lube from home depot on it.
USCGMK1
Reg: 07-24-15
06-21-21 08:42 AM - Post#2821890
    In response to turbo38s10
Thanks for the replies. I sprayed some lithium grease on all the hinges parts and now if I open it slowly it seems to be fine. I have another set in my storage and I’ll get them sent out to get rebuilt. Hopefully these hold up till then.
Execution time: 0.097 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:56 AM
