Username Post: A/C Question...        (Topic#365539)
6T5
"3rd Year Gold Supporting Member
6T5
Loc: Asheville, NC
Reg: 07-22-17
06-17-21 05:42 AM - Post#2821711
Just curious what if any benefit there is to inside air vs. outside air settings on the a/c, thanks...
...Ed
1965 Impala SS
Impalas4ever
Loc: Northern CA
Reg: 09-24-20
06-17-21 09:16 PM - Post#2821750
    In response to 6T5
The outside air benefit is you get fresh air when pulling from the outside. The trade off is that when you just use the inside air, the A/C can remove the heat faster because it has already began removing heat. I guess we can also get into humidity etc.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
06-19-21 06:21 PM - Post#2821820
    In response to Impalas4ever
Recirc reduces the load on the system because you are recirculating cooler/ dehumidified air. That said GM always brings in at least a small percentage of outside air in recirc to avoid sudden fogging in certain conditions.
Recirc ends up lowering the compressor out pressure so less load on the compressor and less HP to run the compressor. I'm not certain when it started but GM started using the term "MAX" for recirc which was somewhat misleading because some people believed that the system worked harder on "MAX" than normal AC mode (outside air); it was just the opposite.
6T5
6T5
Loc: Asheville, NC
Reg: 07-22-17
06-20-21 02:34 AM - Post#2821830
    In response to toro455
Thanks for all of the feedback as it makes all of us wiser with more information...
...Ed
1965 Impala SS
Execution time: 1.631 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:36 PM
