Username Post: 350 Ram Jet fuel pressure regulator test ??        (Topic#365517)
Arkie
Reg: 06-14-21
06-14-21 02:30 PM - Post#2821601
I have a 350 RamJet that was running fine and died at stoplight. I barley got it home and have replaced fuel pump. It has 40 psi past the fuel filter and 40 psi at the rail. In the fuel rail there is another psi check point not 8'' past the pressure sensor and there is no pressure in the rail ? The regulator vacuum line is not split or leaking. I pulled vacuum at the regulator diaphragm and it is not torn. I have Russel push lock lines and Holley Terminator X Max for electronics. I doubt if there is 500-600 miles in my car. Any help would be appreciated. Thank you, Arkie.
Member #409
06-14-21 03:08 PM - Post#2821602
    In response to Arkie
If you have pressure at the rail and no pressure 8" away from it, there is a blockage between those two places. Either that or you are expecting pressure where it shouldn't be.
Where is your regulator mounted?
Arkie
Reg: 06-14-21
06-14-21 04:33 PM - Post#2821605
    In response to Rick_L
There are no restrictions in the rail , and the regulator and return line are on the other side past all injectors= factory GM. Other than Terminator x Max it is just like it came out of the crate from GM. My Holley tech just got on my laptop and the tune has not changed.
Member #409
06-14-21 06:20 PM - Post#2821606
If there are no restrictions in the rail but you say you have pressure at one spot on the rail and not at another, that is impossible. I suspect that both locations are not really on the rail.
06-17-21 11:16 AM - Post#2821723
There won't be any pressure past the regulator. Where is the pressure port your referring to. The only port on my Ramjet is in the middle of the passenger side log. The fuel pressure is completely mechanical, no electronics involved. The regulator bleeds ofF any pressure higher than its set point and the return line is open to the tank, so it won't have any pressure.
Link to regulator.
Link to pressure port.
Edited by acardon on 06-17-21 04:34 PM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-17-21 12:29 PM - Post#2821729
    In response to acardon
http://www.grumpysperformance.com/Feb2021/ffft.gif
Edited by grumpyvette on 06-17-21 12:32 PM. Reason for edit: No reason given.
cbernhardt
cbernhardt
Loc: Lexington,NC
Reg: 08-28-00
06-19-21 03:05 AM - Post#2821786
The Ram Jet 350 specifications call for a fuel pump operating pressure of 43 – 55 PSI. Fuel pressure at the rails should be 41 – 47 PSI. I think my engine measured 45 PSI when new. I added an adjustable pressure regulator and reduced the pressure to around 40 PSI and it ran fine.
Will the engine start and idle?
When you measured the 40 PSI was the engine running?
Evidently got the engine started when the problem occurred, so what were the symptoms?
Does the Terminator have a Limp Mode?
Did you ever have the engine running with the stock GM controller?
Edited by cbernhardt on 06-19-21 04:05 PM. Reason for edit: No reason given.
Execution time: 0.253 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:00 AM
