Username Post: '94 K2500 TBI Idle Control        (Topic#365505)
Che94
Reg: 04-04-21
06-13-21 06:23 AM - Post#2821556
I've thrown a bunch of parts at my '94 350, eventually fixing the true problem with a new fuel pump...the other new parts included the idle control valve and TBI rebuild kit, which pretty much amounts to new gaskets.
The truck runs fine, or at least, normal now with the possible exception of running "rich" when idling, based solely on my subjective "smell" of the exhaust gases. The idle speed is OK/normal(?).
I have to admit I haven't smell tested the exhausts after the engine has gotten up to operating temp.
Any comments or thoughts?
06-13-21 06:59 AM - Post#2821559
    In response to Che94
Is timing set to zero? TBI can be forgiving up 4 degrees of timing. Any more timing and a new eprom chip is better.
'08 GMC Acadia 3.6L SLE
Che94
Reg: 04-04-21
06-13-21 07:19 AM - Post#2821560
Timing is set to zero.
06-13-21 05:30 PM - Post#2821578
Is the O2 sensor original? Are there any codes? Check for vacuum leaks. Most emission hoses should be replaced due to age.
Che94
Reg: 04-04-21
06-14-21 04:10 AM - Post#2821585
No codes but the O2 sensor is probably the original. So far as emission hoses and vacuum leaks, I replaced a couple of hoses and don't "hear" any leaks but will double check those possibilities.
Thanks...
Note: I realized after the OP I had put the question in the wrong (73-91) forum category.
06-14-21 06:52 AM - Post#2821590
It's okay. I'll move your topic. Square bodies had TBI until '91. If you need a troubleshooting guide, send me a message or email. I'll send you a TBI PDF file for troubleshooting.
Sabino
Reg: 07-16-05
06-15-21 06:46 AM - Post#2821625
I’d check if you are getting into closed loop at idle. If you don’t get into closed loop it defaults to some, I think, rich setting. If you don’t have scanner memory is there are some pins on ALDL you can jump which will cause the CEL to flash differently in closed loop.
I had a “lazy” O2 once which changed fast enough to get into closed loop when driving but not fast enough to make criteria for closed loop at idle. It was causing me to fail emissions at idle.
65 Belair 350
68 Camaro 327
93 Suburban 5.7L TBI
Chevytech
Chevytech
Reg: 04-25-04
06-16-21 10:50 AM - Post#2821671
A common problem for a rich idle on these trucks is a bad coolant temp sensor.
See the thread in the link for discussion and testing information.
Execution time: 0.087 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:54 AM
