Username Post: POWERGLIDE CASTIRON KICKDOWN        (Topic#365496)
52chevyproblems
Reg: 06-11-21
06-11-21 09:13 PM - Post#2821507
Hello all,
I just signed up, but I have used this website to solve many mysteries in the past. So I wanted to start by saying thank you.
I have a 52 chevy styleline 4 dr that I just had to switch out the original 235 and pg for a 53 235 and pg. The differences are slight but many.
The issue I just realized was the kick-down link and bellcranks setup for 52 is very simple, and the 53 has 2 bellcranks and multiple rods to make for a smoother pedal.
I want to know if there is a way to run the pg without the kick-down link attached and the pg run as needed; the 52 pg has the manual shift from low to high. So it would be as if the pg doesn't even have a kick-down, right? The 235 has a small amount of power. This car is a daily driver and used at speeds up to 60 for about 50 miles for long drives. Will the pg start to deteriorate if I leave the link off? or will there be no issues? Please help me out.
drtyler
Loc: Georgia
Reg: 05-06-10
06-12-21 03:40 AM - Post#2821511
    In response to 52chevyproblems
I would install the PG linkage as intended by GM. It works pretty good, and the 53-54 PG is considered an upgrade because of the automatic 1-2 and 2-1 shifts.
52chevyproblems
Reg: 06-11-21
06-13-21 06:00 AM - Post#2821554
    In response to drtyler
thanks, I need to buy the setup for the firewall, the bellcrank, and pedal attachment. Know anywhere other than EBAY?
Execution time: 0.308 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:54 AM
