Username Post: 58 seat belts        (Topic#365495)
agius
Loc: british columbia
Reg: 02-14-17
06-11-21 09:52 PM - Post#2821503
Has any one installed seat belts on a 4 door . The front seat doesn't tip forward so I am not sure how to get the middle belt through the top and bottom seat . The outer one can mount on the outside with no issues .Any ideas out there ? Thanks Rick
schudaddie
Loc: SW, MI
Reg: 10-31-01
06-12-21 06:25 AM - Post#2821513
    In response to agius
you might want to look around here for ideas...
https://www.julianos.com/Articles.asp?ID=275
https://www.julianos.com/Articles.asp?ID=242
the second link is for the wrong brand but it'll gave you the ideas on how to do these mountings.
later, bill
agius
Reg: 02-14-17
06-12-21 07:48 AM - Post#2821518
Thankyou for the site info . I will see if they have info on a fixed no tilt front seat application .
JayChicago
JayChicago
Loc: Chicago
Reg: 01-03-13
06-12-21 08:26 AM - Post#2821520
Yeah, this is a problem. The upholstery fabric on the back of these bench seats stretches past the crack between the seat back/seat bottom. No way to get access to that crack to get the seat belt through. I think you would have to remove the hog rings holding the fabric at the bottom, and curl the fabric back to gain access. Probably a simple job for an upholstery pro, but not easy for the rest of us.
agius
Reg: 02-14-17
06-12-21 07:16 PM - Post#2821538
    In response to JayChicago
Thanks Jay , exactly what I was thinking . I have a new interior kit going in and will have the upholsterer create some room to allow the seat belts to slide through .Cheers Rick
Execution time: 0.092 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:12 AM
