Username Post: Removing Door Belt Molding        (Topic#365488)
belairbob50
Loc: OH where rust never sleep...
Reg: 03-17-13
06-10-21 06:43 PM - Post#2821458
On a 1950, I understand from previous postings that I should tape on both sides of the molding to protect the paint. I should use a flat putty knife to pry off the s/s molding. Does it matter if I insert the putty knife at the top or the bottom of the molding? Thanks
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
06-10-21 06:49 PM - Post#2821459
    In response to belairbob50
It does not matter top or bottom. Some of the clips may not survive using this method. The only other way that insures that the clips remain intact is to remove the glass and go at the clips from the inside of the door with a pair of needle nose pliers. This way the clips stay in the moulding...it is however, a lot more work this way.
1951 Fleetline Preservation
belairbob50
Reg: 03-17-13
06-11-21 02:58 AM - Post#2821468
    In response to RAM_51
Thanks RAM
Execution time: 0.173 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:44 PM
