Username Post: How do I get better fuel pressure        (Topic#365479)
2000 4x4 GMC
2000 4x4 GMC
Loc: MS
Reg: 03-02-15
06-09-21 11:48 PM - Post#2821425
For the last 8 to10 years my 2000 gmc k2500 w/454 & 5 speed manual trans has never had good fuel pressure. By that I mean 58 to 62 lbs of pressure when running. When the pump comes on it will jump to 58 lbs pressure then fall to 52 lbs. and hold for 30 minutes. With the engine idling at 750 to 800 rpm the pressure is constant at 49 lbs. quickly pressing the gas pedal it jumps for a moment to 59 lbs then falls back to between 49 & 52 lbs. varies every time it’s done. I’ve had 2 different fuel pumps, 2 different fuel pressure regulators.
Changed fuel filter. Still get same pressures but Now pressure will not hold after key is off. No leaks I can see. Lines are not pinched or plugged/restricted. Can I buy a different brand fuel pump assembly? Delphi,ac delco, standard motor. Which pump & pressure regular is the better to get and keep good fuel pressure?
Senior Moderator
06-10-21 08:14 AM - Post#2821441
    In response to 2000 4x4 GMC
Is the truck running OK?
Do you still have the original injectors?
redvett01
redvett01
Loc: Wickenburg, AZ
Reg: 10-23-03
06-10-21 08:59 AM - Post#2821442
If you are losing fuel pressure when engine is shut off you have a fuel injector leaking. Fuel pressure being low is another issue it should be 60-66 psi so look at the regulator its possibly leaking, check the vacuum hose for gas in it.
K1500 04 Silverado EXT
2000 4x4 GMC
2000 4x4 GMC
Loc: MS
Reg: 03-02-15
06-10-21 08:36 PM - Post#2821464
    In response to someotherguy
Yes the truck runs. Bucks a little at low rpm. At steady throttle on the interstate it will act like I cut the key off & back on for second. Just doesn’t have the power it should have. Before I had the intake problem it ran fair. No missing, just lacking power. It showed up regularly when I pull the gooseneck & tractor. Struggling to pull them and didn’t have the get up and go like it use to have when not pulling a heavy load.
Yes I have a different set of injectors now. Just a little larger than stock, but said they were good fo stock replacement.
Even before I changed injectors I had the same fuel pressure trouble.
2000 4x4 GMC
2000 4x4 GMC
Loc: MS
Reg: 03-02-15
06-10-21 08:44 PM - Post#2821465
    In response to redvett01
That’s odd. Right before I changed the fuel filter it was holding around 51 to 52 lbs pressure for 35 minutes. Didn’t drive anywhere, just changed filter to see if I could improve pressure. Used a mirror to watch pressure regulator with pump running & after. No leaks visible on regulator, line connections, or coming out of vacuum line. I can’t get to the regulator unless I take off the upper intake or pull the distributor.
454cid
Loc: West Michigan
Reg: 02-18-12
06-22-21 02:44 PM - Post#2821960
That sounds more like small block pressure.
99 K3500 RCLB
454cid
Loc: West Michigan
Reg: 02-18-12
06-22-21 02:48 PM - Post#2821961
I've been pretty pleased with my Denso pump.
Do you have the flat four or square four plug at the pump? GM redesigned the plug and many pumps provide a new connector to splice into the truck's wiring harness. I wonder if your pump trouble is electrical. My ground was questionable when I changed the pump last.
99 K3500 RCLB
Execution time: 0.363 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:14 AM
