Username Post: Shudder under load and dying on stop        (Topic#365434)
Aquavit750
Loc: Reno, NV
Reg: 11-28-17
06-05-21 10:41 AM - Post#2821169
1966 impala 283 3-on-the-tree. Starts to shudder around 2200 rpm. The feeling was as if there was water in the distributor cap. Checked fuel pump. It works. Started to replace electrical components. Wires, plugs, coil even a new distributor as the previous one was 55 years old. I still get popping and shudder. Now the car dies at idle. Can anyone help me pin down what I’m missing. Thanks for any help.
J-Dub ‘66 impala base
brasii
Loc: FRANCE
Reg: 11-09-07
06-05-21 01:48 PM - Post#2821175
    In response to Aquavit750
Can you put a little video ??
impala 66 convertible
toro455
toro455
Loc: Western NY
Reg: 06-15-02
06-05-21 09:21 PM - Post#2821194
Just a guess but it could possibly a needle and seat issue or a float causing flooding.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
06-06-21 05:24 AM - Post#2821202
I'm not 'clear' on what you have done so far, but:
Could simply be in dire need of a full tune-up. Points, plugs, rotor, distributor cap , and an ignition timing check/re-set. AND, replace fuel filter.
A cracked distributor cap can allow moisture to enter, but that usually does not allow the engine to run at all (until it dries, and then it will run fine).
I'd start with those because there is no 'waste' there. Next would be plug wires (unless they visually looked bad; then they would be in step 1).
Coil? Not causing your problem. But, they are not expensive and IF you just want to replace it, get one that is oil cooled (not epoxy).
AFTER ignition is verified to be good, adjust carb fuel mix (if necessary).
I'm not going to assume you have no experience with tuning a 'points' system, so I'll skip any 'how to' stuff. There IS a process that requires following to get it right. Refer back if necessary.
Pete
06-06-21 09:42 AM - Post#2821218
what kind of distribiter did you get? you may want to do a compression test. do you have headers?
Oshawa65SS
Loc: Grande Prairie AB & N...
Reg: 09-22-14
06-06-21 12:33 PM - Post#2821225
I'm thinking carb issue but pull the fuel sender/pickup and see if the tank is rusty or there's water, and that the filter sock looks good.
Check all the vacuum hoses too.
Ryan
Build date Dec. 21 '64 Oshawa
steve65
steve65
Loc: New Westminster BC
Reg: 09-25-13
06-06-21 02:23 PM - Post#2821235
    In response to Oshawa65SS
I'm with Ryan on one. Check the fuel filter sock on the sending unit. And get a vacuum gage and see what you have at idle and as the RPM goes up. I'm guessing a vacuum leak has opened up.
Steve
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
Aquavit750
Loc: Reno, NV
Reg: 11-28-17
06-06-21 04:44 PM - Post#2821244
    In response to japete92
Thanks Pete. So what I’ve replaced so far were the plugs, wires, distributor, cap, points, rotor and coil. I checked the carburetor float and seat today it is fine. I had it all over town Friday night and Saturday morning it warmed up about halfway, died and hasn’t started since.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
06-07-21 03:46 PM - Post#2821305
If it's happening only when hot I wonder if it could be vapor locking. I've knock-on-wood never had that issue so I'm not certain of other symptoms.
How long have you had the car without issue?
I had a strange issue which resulted in random stalling when a fuel line (soft line) was pinched above the tank. It was strange but it would run fine and then just die.
Edited by toro455 on 06-07-21 03:47 PM. Reason for edit: No reason given.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
06-08-21 05:35 AM - Post#2821333
A few simple fuel system 'checks' that I'd perform next:
Replace the fuel filter. They are too inexpensive to 'check'.
Fuel pump performance 'fluctuates' on a 'dying' pump; often producing insufficient pressure to accommodate rpms. 'Dead'; the car won't start. Check the pressure (it should be around 6-7 psi).
As already suggested (and especially if the the car has ever 'sat' for a long period of time), check the fuel 'sock'.
Just info:
If any of the above resolve your problem, don't declare victory yet.
IF the car has 'sat' for along time any time in its life; there's a good possibility the gas tank's interior is corroded and/or 'coated' with all kinds of nasty gunk. Particles slough off, get into the fuel, and clog up anything/everything. Some particle are so 'fine' they will pass thru a filter and 'clog up' anything down stream of it (carb).
So, there may be a period of initial 'success' but as time passes, the systems may return. AND you have to 'clean up' EVERYTHING again.
Some folks 'clean/flush' a gas tank. Because a brand new one costs about $200 (Spectra; a Canadian Co.), I would replace rather than 'clean'.
Pete
Impalas4ever
Loc: Northern CA
Reg: 09-24-20
06-11-21 08:57 PM - Post#2821504
Can you please explain the popping. When does it occur? Through the carb? Exhaust? On acceleration, or deceleration, at a steady RPM? How many miles on the motor? Is the motor stock? When did this issue begin, was it running fine one day and parked then run bad? Did it happen when accelerating hard? Stop replacing items. Diagnosing is your answer, not throwing money at it.
Execution time: 0.515 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:44 AM
