Username Post: 2 Spd Wiper Switch 1 Spd Motor        (Topic#365425)
jadelcamp
Reg: 07-05-10
06-04-21 06:27 AM - Post#2821116
I am working on getting my 1965 C10 dash wiring completed (1st time I've ever attempted this) and it turns out I have a single speed wiper motor, but a 2 speed wiper switch. The single speed switches online have 2 terminals in the back and the 2 speed switch has 3. Does anyone know if I can use a 2 speed washer switch and just wire two of the terminals? If so which ones and what color wires go to which terminal? Thanks!
Edited by jadelcamp on 06-04-21 12:11 PM. Reason for edit: No reason given.
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
06-06-21 07:46 AM - Post#2821209
    In response to jadelcamp
I believe it will work. Reading through the description in the first link on operation of a 2 speed motor, the switch either grounds one or both of the wires to operate the motor in high or low speed. If you connect your harness to the high speed connection on your switch, it should run in both high and low switch positions.
https://sites.google.com/site/chevvyeddie/home /tes...
http://67-72chevytrucks.com/vboard/showthread.php?...
jadelcamp
Reg: 07-05-10
06-08-21 05:36 AM - Post#2821334
    In response to jktucker92
Thanks! I will give it a go.
Execution time: 0.119 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:48 PM
