Username Post: Need MIG Welding Tips        (Topic#365363)
Anonymous
05-29-21 12:36 AM - Post#2820743
Bought a machine for my mini-workshop. Have Not any idea about how to set up a MIG welder. Mig model: Goplus MIG 130 Welder.
Edited by Tony on 06-03-21 12:47 PM. Reason for edit: Removed SPAM content
51 AD 3100
Loc: Grant, AL
Reg: 08-30-20
05-29-21 03:10 AM - Post#2820746
    In response to Roger Parker
who makes Goplus welders. they look a bit cheap. id stick with a brand name background thats trusted. Hobart is good and basically Miller guts . Lincoln is good too. but to answer your question, youtube has a few videos how to set up your mig welder. just that easy.
Life's more fun, in a '51
xstuntman
Loc: west Texas
Reg: 04-13-09
05-29-21 04:22 AM - Post#2820750
If they gave you the mask-on-a-stick go ahead and buy an auto dimming hood from HB because you will need both hands. I'd add a welding blanket and those magnets they sell are pretty handy too. Lots of good welding vids on the 'tube.
Most importantly cover up what you don't want hot boogers burning holes thru because they do at lightning speeds. My big toe currently has a hole to match the one in my new walking shoes. The hotter the weld the farther and hotter the boogers fling.
Edited by xstuntman on 05-29-21 04:27 AM. Reason for edit: No reason given.
Mel Foye
Mel Foye
Reg: 09-29-00
05-29-21 10:12 PM - Post#2820799
    In response to xstuntman
The hot ones my buddy hates are the ones that go in his ears.
hilandr451
Moderator & "12th Year" Gold Supporting Member
hilandr451
Loc: Houston, Texas
Reg: 01-02-02
05-30-21 03:05 PM - Post#2820848
    In response to Mel Foye
Here's my tip:
Take your phone out of your shirt pocket before you weld. It turns out Otter doesn't make spark proof protectors. (speaking for a friend)
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L,
1966 C20 Custom Camper "Rattle can primer red" 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
05-31-21 06:15 AM - Post#2820880
    In response to hilandr451
http://www.grumpysperformance.com/weldsa3.jpg
http://cdn0.grizzly.com/pics/jpeg500/h/h9888- fb155...
https://i.ebayimg.com/images/g/ZAoAAOSwubRf VWk6/s-...
https://www.millerwelds.com/-/media/miller-electr i...
http://www.grumpysperformance.com/weldb8.jpg
Edited by grumpyvette on 05-31-21 03:05 PM. Reason for edit: No reason given.
Site Ambassador
05-31-21 10:30 AM - Post#2820897
I had one slam dunk in my ear once. Burned a hole in my eardrum and caused an infection. Now I have hearing loss in that ear and it rings constantly, otherwise known as tinnitus.
1957 Cameo Carrier
Mel Foye
Mel Foye
Reg: 09-29-00
05-31-21 03:43 PM - Post#2820919
I will be of little value to you on your question except have you contacted the manufacturer for written guidance or internet?
I have seen evening classes on Mig welding at some high schools here in my state.
Did Grumpy leads help?
TAT_2
Site Ambassador - Member #26 - "20th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
06-01-21 11:25 PM - Post#2820997
https://welditmyself.com/goplus-mig-130-welder -man...
GOOD GLOVES SAVES INKED HANDS
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANNIV- RUBY RED- LT1/6-SPD/RAG TOP
QUOTE FROM HELEN
06-27-21 10:03 AM - Post#2822182
    In response to
sorry but your late to the party. you should have asked which machine to buy before you bought. practice is the only thing that can bring up your skill level. youtube will be a big help. you can google a manual for just about any machine they are all about the same. dont weld with your mouth open. welding with big clumbsy gloves is difficult. weld in the sunlight or use some other light source. ground to clean bare metal as close to the weld as can.
LtFrankDrebin
LtFrankDrebin
Loc: Coopersburg, PA
Reg: 01-25-01
07-27-21 06:35 PM - Post#2824010
    In response to
I taught myself how to MIG weld back in 1996 when I bought a Sears Craftsman unit. Use the appropriate wire and dial-in the wire feed speed. The wire speed should give a nice smooth, consistent bead. I always find myself using the next higher heat setting than recommended for better penetration, but be careful with sheetmetal. Don't do a continuous bead more than an inch or so or you'll warp the metal. Also, make sure the edges you're welding are clean bare metal free of rust, grease, etc. And, weld with the gas. Don't use flux core.
'56 210 Townsman wagon 6cyl/3spd OD | '58 Impala Sierra Gold 348
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
08-14-21 07:45 AM - Post#2825115
    In response to
It sounds as though this welder is a "flux core wire" welder. Does it have the capability of being converted to a "gas" welder? My opinion, but as far as I'm concerned, for me, gas (a true MIG; Metal Inert Gas) is far better.
1951 Fleetline Preservation
monty56
monty56
Reg: 04-26-04
08-14-21 09:07 AM - Post#2825121
    In response to RAM_51
You need both, gas on small wire, thin metal and larger wire w/ flux core for thick metal. I did my frame mods w/ flux .035 and replaced sheet metal cab w/ gas and .020
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
Site Ambassador
08-15-21 05:40 PM - Post#2825245
    In response to monty56
You can use gas on thicker metal too.
1957 Cameo Carrier
Execution time: 0.083 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:58 AM
