Username Post: aT 65 LEARNED SOMETHING.        (Topic#365138)
89RS98Z28
89RS98Z28
Reg: 10-14-04
05-07-21 12:07 PM - Post#2819452
Got up this morning and saw that I had left trunk lid open. Light was still bright and on entering car chimes and light seemed good. Turned key heard click and saw gauge drop below 5 volts and nothing. Let off the key lights and chime worked. Turn the key nothing.
Tried jumping the car to no avail. Took battery out to have tested. Guy says it shows good 99 percent. Asked if the tester put battery under load and was told yes.
Started home to pull starter to have tested. Called a friend on the way home, told him what was going on.
He tells me to never try and crank one with low voltage, tells me to smack the starter a couple of times before pulling it and then try to start it. Lo and behold started right up.
Glad most of my friends are smarter than me. Seems the bendix had stuck. This appeared as a short to me. Just glad the old girl is still ticking.
A lesson learned the hard way is not easily forgoten.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
06-16-21 05:35 PM - Post#2821696
    In response to 89RS98Z28
Just FYI if it happened once it may happen again.
Glad you got it going though
Old School GM fan FOREVER
Execution time: 0.074 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:43 AM
