Danchuk
Username Post: CARB        (Topic#365129)
Big T
Big T
Loc: Simi Valley CA
Reg: 04-14-06
05-06-21 04:32 PM - Post#2819400
Have a create 350HO deluxe. Came with the 650 carb**** mounted to the motor. Total run time at various rpm was 10 hours. Car has not been off the stands-----for ever.
the last time I ran the motor was maybe 6-7 months ago. (pre transmission problem).
Quick start up, responsive throttle to various rpm. Ran good, no problems. Normal shut down.
Problem: Engine turns over however the Carb is not getting any fuel into the bowl. Pump new (at that time) all new gas lines,(stainless) two inline filters + the Carb filter. Gas tank was was dipped and coated many years ago but did not see fuel before 2019.
CT friend came over and started to go through the system. gas tank to carb and everything between them. All are working however he found that the fuel stops at the carb.
thanks in advance
tom
this is how far we got. Before I send the carb to a shop, we hoped someone has some ideas.
tom
**** carb part number is 80457-2 2350
Tom
55 4 door BelAir
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
05-06-21 04:43 PM - Post#2819401
    In response to Big T
Sounds like a stuck needle
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
Execution time: 0.105 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:10 PM
