Username Post: 4 Speed Conversion        (Topic#365107)
Bradfordjlenz
Reg: 10-23-19
05-04-21 02:17 PM - Post#2819272
Hi, I’m planning on converting my 2 speed power glide to a 4 speed super T10 in my 66 Caprice.
Just wondering if I need to change the cross member and anything else that could help.
Thanks in advance
Brad Lenz
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
05-04-21 03:06 PM - Post#2819273
    In response to Bradfordjlenz
Check out the “Automatic to 4 speed” article in the clutch/transmission section of the “Reference Section” above. It’s a good place to start.
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
Bradfordjlenz
Reg: 10-23-19
05-04-21 03:59 PM - Post#2819275
    In response to Gaspains
Brad Lenz
05-04-21 10:49 PM - Post#2819289
it is and aint as easy as it sounds. you can just get parts and slap um together as is often done.
or you can get as technical as you want.
as i see it, transmission to engine alignment is very important and slapping parts together is just that. dialing in a bellhousing so that the trans is aligned to the engine is very time consuming but i feel is well worth it. there is up-down, left-right, and angles up-down, left-right to consider or not. i would try to get the bellhousing milled so that the two faces are parallell for a start. that will help or cure the angles issue. the left,right,up,down will need to be done with dowel pins. overkill? maybe. am i nuts? for sure. you decide what you want.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
05-05-21 06:38 AM - Post#2819297
Here's a couple of links you may find helpful:
https://www.chevelles.com/threads/course-101-on -be...
https://www.chevelles.com/threads/bell-housing- dia...
And here's one vender I've bought parts from that has met my standards:
https://www.4speedconversions.com
Glad to see ANY manual transmission installations.
Pete
ImpalaSam
Loc: Inman, SC
Reg: 07-02-09
05-05-21 11:28 AM - Post#2819316
    In response to japete92
I swapped my '65 Impala from PG to T10 and was able to use the original crossmember but I did have to elongate the transmission mount slots slightly.
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
05-07-21 09:42 AM - Post#2819444
    In response to ImpalaSam
You should be able to use the same crossmember.
Here is where I am at with my conversion:
Ted
astrojet427
astrojet427
Loc: Vancouver, B.C.
Reg: 11-22-05
05-08-21 09:34 AM - Post#2819489
    In response to brickwhite
With regards to using a Super T10 in a 66 (or 67), your shifter set up may require some additional conversion info.
I am pretty sure if you use a Hurst shifter with the Muncie trans, you need a 4205 (I think) mounting plate.
Does anyone know if the 4205 plate is also used for a Super T10, or do you need to fab one Or use another numbered plate? Input please someone?
I'm thinking of going with a ST10 in the future as well instead of using the Saginaw and because Muncies are getting pricey. ST10 is a good option and good trans.
Sorry OP, no intention to hijack your thread. But shifter issues always seem to come up with B bodies. I think someone on this board put an ST10 behind big block '66. Maybe he'll chime in.
1967 Impala SS. 327-Turbo 400; 12 bolt-3.55 gears. A few photos of my '67.
1972 Corvette Convertible Mille Miglia Red 4 speed.
1963 Cadillac Eldo-Triple Black.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
05-08-21 03:05 PM - Post#2819505
    In response to astrojet427
4205 plate on each 4-speed application
astrojet427
astrojet427
Reg: 11-22-05
05-08-21 06:39 PM - Post#2819521
    In response to aghaga
Thank you aghaga. So if I understand correctly, 4205 mounting plate for hurst shifter for either Saginaw, Muncie or BW ST10. Then You just need to get the correct shifter arms for the tranny used?
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
05-09-21 05:22 AM - Post#2819541
I believe the Hurst installation 'kit' (the correct one for the transmission) includes what is required.
Attached is one for a Muncie.
Pete
Attachment: hurst_install_inst_huu-3733163.pdf (60.43 KB) 18 View(s)
astrojet427
astrojet427
Reg: 11-22-05
05-09-21 04:27 PM - Post#2819593
Thanks for that attachment Pete. I wonder if there is one for a Hurst Saginaw setup. Probably not huge demand, but most small block 4 speed cars from what I’m aware came with a Sag. So hurst must have made a kit you’d think. Never seen it discussed.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
05-09-21 04:44 PM - Post#2819595
https://www.summitracing.com/parts/huu-3734297 kit will work just need the 4205 mount
Attachment: DSCF0007.JPG (98.45 KB) 0 View(s)
4205 vs common mount
Attachment: DSCF0011.JPG (59.44 KB) 0 View(s)
4205 is the taller one
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
05-10-21 06:11 AM - Post#2819622
Hurst certainly used to provide the installation kit for the 4 speed Saginaw. I have not looked for one in years.
As for 4 speed Saginaws for 'most' sbc? I'm not a historian but I believe in the full size Chevy's (thru '66, or maybe even later), the 4 speeds were either BW (before early '63) or Muncie (after early '63).
Chevelle, Camaro, Chevy II, Vega were more readily available with the Saginaw 4 speed.
Here's another attachment with some useful info.
Pete
Attachment: transmission_id_chart_3917535.pdf (2.83 MB) 8 View(s)
Execution time: 0.07 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:09 AM
