Username Post: Borgenson steering or rack and pinion        (Topic#365101)
Joelinda5386
Reg: 07-18-16
05-03-21 08:05 PM - Post#2819234
My car is wandering all over the lane. It has a borgenson steering box on it and I was thinking about rack an pinion any advice please
05-04-21 04:04 AM - Post#2819242
    In response to Joelinda5386
So what is the root cause of this, gear box play, linkage wear? Alignment?
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
05-04-21 05:40 AM - Post#2819251
The Borgeson box instructions 'recommend' about 4 degrees of positive caster (I don't remember the exact number).
I also don't remember the exact steering ratio of the Borgeson box, but it's approx 15:1, compared to the GM OEM 22:1 (approx).
The additional caster is REQUIRED to provide the proper 'return to center' forces that steering ratio requires. The OEM upper control arms can't give that much (any more than about 1 1/2 degrees is pushing their limit). Without the additional caster the steering will 'wander' and holding a straight line is a chore.
Tubular upper control arms with built in 5 degrees of + caster solve the problem.
Because the hydraulic pressure is applied directly into the steering box, a pressure regulator/reducer can fine tune, and smooth out, the steering (another source of possible steering instability with the integral steering box).
Add a sway bar and roll in turns is reduced.
All the above is based on ALL other components being in proper operating condition. No issues with tires, bushings, alignment , or ANY degradation of ANY OEM part.
After spending WAY more than I originally envisioned, my steering is a little better than a proper OEM system, but the gain was not commensurate with the costs. If I could take a 'mulligan', I would have simply rebuilt my leaking control valve (the only problem I was having).
Pete
Joelinda5386
Reg: 07-18-16
05-04-21 05:35 PM - Post#2819279
New gear box new linkage fresh aligned
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
05-05-21 06:29 AM - Post#2819296
Aligned to what specs?
OEM specs (basically neutral/zero caster) do not suffice with the integral steering boxes. They require the approx +4 degrees to 'return to center' properly, and to NOT 'wander'.
Pete
05-05-21 08:08 AM - Post#2819300
    In response to japete92
Good info,japete, 4 degrees caster is just about impossible on these cars with stock suspension, I never get more than about 1.5 without putting the camber out of range.
Edited by Shepherd on 05-05-21 08:11 AM. Reason for edit: No reason given.
Execution time: 0.171 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:26 AM
