Username Post: Horn Button        (Topic#365094)
jimshoe52
Reg: 01-08-12
05-03-21 06:20 AM - Post#2819195
I have a 1990 Silverado Xcab.Brought it in for inspection today and discovered the horn didn't work. The mechanic checked it and said there was power to the horn. And so, he said the horn button pad in the steering wheel may have gone bad. He said that it would be more expensive replacing the button in the steering wheel. And so he advised that running a wire from the horn to the dash and installing a button on the dash would be cheaper (~$110.00). Is this a proper way to go?
Edited by jimshoe52 on 05-03-21 06:20 AM. Reason for edit: No reason given.
Senior Moderator
05-03-21 07:20 AM - Post#2819199
    In response to jimshoe52
While it's possible the button may have gone bad, it isn't common. You can check it for continuity with an ohmmeter to be sure. If it's indeed bad, you can easily find another in a boneyard - same button used for quite a few years, and it just pops off/on.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-03-21 05:19 PM - Post#2819227
    In response to someotherguy
It is very likely the cancelling cam lock broke. Pull the button and I bet the wire is just laying in the hole. The wire is supposed to be spring retained into the hole.
I do not like doing dash buttons. Not that hard to fix
Old School GM fan FOREVER
Execution time: 0.152 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:30 AM
