Username Post: Drivers Door Inside Lock 1965 Chevy II        (Topic#365087)
05-02-21 01:19 PM - Post#2819168
Is there a secret to lock the door from the inside and then get out? I am able to lock it with the key, but I cannot figure out the correct procedure.
29-41, 42-48, 49-54 Moderator
Member #409
05-05-21 02:35 PM - Post#2819329
As you've discovered, you can only lock it by using the key.
Regard it as a bonus, you can't shut the door with the lock enabled inadvertently.
Execution time: 0.136 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:35 AM
