Username Post: Drivers Door Inside Lock 1965 Chevy II        (Topic#365087)
Member #189 Moderator and "21th Year" Platinum Supporting Member
05-02-21 02:19 PM - Post#2819168
Is there a secret to lock the door from the inside and then get out? I am able to lock it with the key, but I cannot figure out the correct procedure.
29-41, 42-48, 49-54 Moderator
Member #409
05-05-21 03:35 PM - Post#2819329
As you've discovered, you can only lock it by using the key.
Regard it as a bonus, you can't shut the door with the lock enabled inadvertently.
04-27-22 07:28 PM - Post#2840387
    In response to Rick_L
Thanks Rick. Sorry for late reply.
Frank_T
Loc: PA
Reg: 12-02-02
03-05-23 08:55 AM - Post#2855354
yes there is a secret... If you push the door handle down on the inside it will lock the door
03-17-23 06:37 PM - Post#2855890
    In response to Frank_T
Right, but it will not stay locked when you get out and shut the door. It unlocks. Then you lock with the key.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
03-20-23 05:24 PM - Post#2855974
After pushing the lock button down, then hold the outside button (the one you press to open the door) while closing it....
Attachment: door_lock_still.jpg (31.03 KB) 1 View(s)
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
03-20-23 05:37 PM - Post#2855977
    In response to docjns1
Thank you for your response. The Chevy II does not have the button to push down in the drivers window surround. Rick_L has the correct answer. Can only lock with the key after you lock the passenger side and ge out of the drivers side.
Execution time: 0.084 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:50 AM
