Username Post: 88-91 front turn signal assemblies        (Topic#365081)
05-02-21 06:53 AM - Post#2819144
Has anyone polished up their front 88-91 plastic assemblies? Mine are starting to look hazy. The new cover protects them from sun damage. The assemblies are flat. The interior has "hump lines".
Attachment: leftlight.jpg (104.47 KB) 3 View(s)
Left light
Attachment: rightlight.jpg (104.84 KB) 2 View(s)
Right light.
'08 GMC Acadia 3.6L SLE
Site Ambassador
05-02-21 07:16 AM - Post#2819146
They should polish up nicely. If they aren’t too bad you can start with rubbing compound and graduate to less aggressive compounds. If the rubbing compound isn’t enough, you can wet sand them a bit with 1,000 grit paper and then polish. You can do it by hand, but it takes a bit of work. If you use a buffer be careful of getting the lens too hot. Run the buffer at the slowest speed you can. Or if your buffer isn’t variable speed, keep it moving to not build up too much heat.
1957 Cameo Carrier
05-02-21 07:51 AM - Post#2819149
    In response to wagonman100
I have a 12V cordless palm sander. It should turn slow enough. A few 3" discs are cheap.
Do you know of any spray/compound that can remove clear polish or paint? My other vehicle has sprayed clear on it. It needs to be stripped off before polishing the poly again. Is it even possible? Normally, I buy new assemblies then clear tint them for protection. However, the costs of self adjusting light assemblies is crazy high.
Senior Moderator
05-04-21 07:42 AM - Post#2819257
If the light polishing won't clean them up then go ahead with fine grit sandpaper and wet sand them, then polish. I follow that up with wax/grease remover (prep spray, TSP, your choice of whatever won't attack plastic) and clean them thoroughly then apply fresh clear to them so they stay shiny for a long time.
Those housings will shine up very nicely. Even ones that are very yellowed will shine up, too - about the only ones that can't be fully revived are the ones that have tons of little cracks in the plastic.
Execution time: 0.143 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:15 AM
