Username Post: 1961 Biscayne front springs        (Topic#365069)
Bdogft
Reg: 12-05-10
05-01-21 08:15 AM - Post#2819081
61 Biscayne front end lowered by cutting 2 coils for a spring height of 23 3/8" I want to raise the ride height. Is it as easy as replacing with stock springs or will shocks need replacing? Cars is a 350, do I want small block springs or 409?
Thanks for the help
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
05-01-21 03:39 PM - Post#2819095
    In response to Bdogft
If you want the nose at stock or a bit higher, moog 6004’s are good. I would say the shocks you would have to check what you have to see if they were shorter than stock- changed with the cut coils?
Member #2194
Execution time: 0.147 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:06 PM
