Username Post: rear shocks in 1980 Camaro        (Topic#365045)
Kevin Blank
Reg: 10-01-20
04-28-21 03:13 PM - Post#2818952
Help,
I am replacing my rear shocks in 1980 Camaro base model. When I removed my old shocks, I broke off 2 upper bolts, 1 on each side. I will probably have to drill out the broken bolts and am guessing I will end up destroying the J-Nuts (Clip Nuts). I have spent hours trying to locate 4 new bolts and J-Nuts that I can use when I install the new shocks. I cannot seem to locate a source. I find the bolts and J-Nuts for front leaf springs and for lower front shocks, but not the rear upper shocks. Any suggestions are greatly appreciated. Kevin
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-02-21 12:55 PM - Post#2822508
    In response to Kevin Blank
Napa sells generic J clips in 5/16" which should be what your upper shock mount uses. They have a long enough clip to fit over almost any situation.
https://www.napaonline.com/en/p/NDP6501051?cid=p ai...
1969 Suburban 2wd 350
1939 Chevy pass. coupe 350/700R4
1937 Austin gasser 327/TH350
Execution time: 0.189 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:36 AM
