jvahila
Loc: Canton Ohio
Reg: 11-07-17
04-26-21 04:33 AM - Post#2818802
Does anyone have pictures of how the weather strip installs on the trunk lid? the piece I have kinda looks like a "V" with one "leg" longer than the other? This is on a 1954 Bel Air 2 door Sedan
Edited by jvahila on 04-26-21 04:41 AM. Reason for edit: No reason given.
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
04-26-21 10:55 AM - Post#2818822
In response to jvahila
1953 Fisher Body Service News on installation of trunk weatherstrip....1954 would be the same.
1951 Fleetline Preservation
'50 Styleline DeLuxe 4 DOOR SEDAN (Mist Green) |
1971BB427
Loc: Portland,Or
Reg: 12-06-09
04-26-21 11:13 AM - Post#2818823
In response to RAM_51
The curved sort of knife edge lip points outward when installed correctly. That's what the factory did, and what Steele Rubber says is correct.
1969 Suburban 2wd 350
1939 Chevy pass. coupe 350/700R4
1937 Austin gasser 327/TH350
RAM_51
Reg: 12-28-02
04-26-21 10:27 PM - Post#2818860
For what it's worth, on my Fleetline (not a 54 but completely original), the body seal and the lid seal overlap about an inch.
jvahila
Loc: Canton Ohio
Reg: 11-07-17
04-27-21 08:39 AM - Post#2818879
Thanks For the Help Guys!!
RoseHank
Reg: 04-09-21
09-18-23 06:50 AM - Post#2862633
In response to 1971BB427
Great instructions on installing trunk weatherstripping. Did not overlap the strips but seems to seal fine. My next project on my 54 Two Ten 2 dr is install the weatherstripping around the doors; however, I can not find good directions and obviously don't find to mess this up. Any directions/guidance is appreciated. Randy
RAM_51
Reg: 12-28-02
09-18-23 09:22 AM - Post#2862641
In response to RoseHank
Randy, These, I think, will be the most helpful scans. Although they are both 1953 information, what is presented applies also to the 1954 models. The first is an explanation of how the door weatherstrip profile differs from that of 1952 and its correct orientation. The second is a step by step instruction on how to install the 1953 door weatherstrips.
