Username Post: Wheels        (Topic#364993)
tooomuch7
Loc: Hartford Ohio
Reg: 03-18-02
04-23-21 07:58 AM - Post#2818602
I have had the same Cragar wheels on my 57 for 44 years now,The fronts are 15x4 and the backs are 15x7.They don’t make the same wheels any more,they are slightly different,I have a front wheel that’s bad,and even if I wanted to buy the new style the 15x4.5 they are all out of stock,so I was thinking of going with the 15 x6 on the front,anyone have any problems with that size of a wheel on the front.I will be buying all four wheels so they match.
http://www.picturetrail.com/gallery/view?p=999&gid=5387542&uid=2695815&members=1
55MAS
Loc: North Coast, USA
Reg: 12-19-01
04-23-21 09:52 AM - Post#2818612
    In response to tooomuch7
Those and a new set of tires and you should be happy. 6 on the front is a good choice. 6 or 7 for the rear. But a matched set make sense.
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
04-23-21 05:30 PM - Post#2818633
do you have front disc brakes?
what type of set up are the disc brakes?
what spindles, brackets?
if stock hubs on front 6" wheels will work just make a measurement for desired offset.
VC56S 2 door Sedan, 40 Years
tooomuch7
Loc: Hartford Ohio
Reg: 03-18-02
04-24-21 04:16 AM - Post#2818659
    In response to Bad56Sedan
I did change the front to disc brakes a few years ago.I don’t remember off hand the name of the kit I used,but they are bolted to the stock spindles.I’ll have to get my records out .
YOUNG57
Loc: Tennessee
Reg: 12-06-10
04-24-21 08:41 AM - Post#2818682
I have Cragar S/S Super Sport 15”x7” with P225/70R15s all the way around on my 57 with (almost) no problem. The only time the fronts rub is when turning hard and hitting a rise at the same time, like going down my driveway and turning onto the street.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
04-25-21 05:28 AM - Post#2818721
I put 15x6 on all four corners of my 1953 Sport Coupe with 4-wheel disc brakes. They worked out great. I could have gone with 15x7 on the rear but I decided it might be nice to actually rotate the tires...
If they fit my '53 they should work fine on your '57.
Vern
1930 DeSoto Business Coupe- 350 Chevy V8, EFI, 4-wheel disc brakes, Wire Wheels, TH400, S-10 Rear, A/C
55MAS
Reg: 12-19-01
04-25-21 06:13 AM - Post#2818727
Execution time: 0.087 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:17 AM
