Username Post: 1962 Door hinge alignment ?'s        (Topic#364962)
62stlragtop
Loc: Portland Oregon
Reg: 04-16-07
04-20-21 01:11 PM - Post#2818415
Hey, I just rebuilt my door hinges on my 62 2Dr hardtop and now need to align my door. Has anyone had any luck doing a door alignment without removing the front fender? I would rather not take the front fender off if at all possible. Thanks for any tips/suggestions that you can send me!
Site Ambassador
04-20-21 02:19 PM - Post#2818416
    In response to 62stlragtop
Unfortunately the best thing you could have done was to mark the hinge location before you removed them. I generally do it by outlining the hinge with masking tape. That way you just remove the masking tape when you’re done. No permanent marks.
There may still be witness marks on the hinge post that can get you close. You should be able to get a wrench on the hinge to pillar bolts, but it’s not the easiest thing.
I would install the hinges and tighten them enough that they won’t move on their own with the door hanging on them but would with some encouragement. Then you can get them to move with a block of wood and a hammer. Moving them forward or up and down won’t be so bad. If they need to come back you may have to loosen one at a time. Loosen the bottom one and lift the back of the door then tighten them loosen the top one and let the door drop back the needed amount and then tighten. You can use that method to move them forward too just reverse which hinge you loosen and lift or let the door drop to move the hinges. You may need two people, one to hold the door and the other to loosen and tighten the hinges.
1957 Cameo Carrier
62stlragtop
Reg: 04-16-07
04-20-21 07:23 PM - Post#2818429
    In response to wagonman100
Yeah, the masking tape idea would have been a good one. Although the door was really needing to go forward and in anyway. I am using the tape on the lower hinge as a reference. Looking like I am going to have to remove the fender to do this right, I cant really get to these lower hinge bolts. Is the front fender difficult to remove? How is the rocker trim (ss car) attached to the front fender?
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
04-20-21 08:09 PM - Post#2818432
The rocker trim has a hex nut on a stud on the front fender connection point and the same hex nut by the rear wheel well opening. The rest of the molding is held in place by large push in clips in between the two hex nuts (if the studs do not break off ) Use a large sturdy scraper to pry the clips loose (they have large push in wires so they will take some effort to pry them loose.
The front of the fender is attached to the radiator support and to the front painted panel below the headlights and bolted to the top of the radiator support. The hood may have to come off since its supported by the hood hinge bracket bolted to the inner fender. Only the 2 bolts holding the hood hinge mounting bracket to the firewall will hold the hood in place if the fender is removed.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
04-21-21 01:39 AM - Post#2818437
    In response to pvs409
If you remove the hood, drill a very small hole behind 1 hood bolt on each side. Drill close to the bolt amd it can’t be seen. Drill through the hinge and the lower layer of the hood and the drill bit can be inserted in the hole to align the hood when you reinstall it.
Member #2194
62stlragtop
Reg: 04-16-07
04-21-21 07:02 AM - Post#2818452
Thats good to know about the hood. Seems like the fender removal will need lots of bolt penetrating spray so i dont break any bolts... This is turning into a multi day project. I'll have to weigh the pros vs cons to waiting to do this in the winter.
62stlragtop
Reg: 04-16-07
04-21-21 07:02 AM - Post#2818453
    In response to DonSSDD
Thats cool! Like the advice for easy installation.
62stlragtop
Reg: 04-16-07
04-21-21 12:36 PM - Post#2818486
Do you know if its possible to tap out the hinge pins without removing the hinges from the car? That would save me some time from pulling the front fender off to realign door...
Bubpletop62
Loc: Bakersfield, CA
Reg: 03-21-06
04-23-21 10:13 AM - Post#2818613
Unfortunately the pins will not ‘tap’ out. I replaced all my pins which were pressed in. The hinges will have to be removed. The whole process is involved but is doeable.
Dennis Bubp
Dennis Bubp
'62 Belair Sports Coupe
drbubp@hotmail.com
62stlragtop
Reg: 04-16-07
04-26-21 08:27 AM - Post#2818818
    In response to Bubpletop62
Project update
I was able to tap the hinge pins out of my hinges and just remove the cast hinge from door. I then took my cast hinge half to the bench and pressed in my bushings. This made the project a bit easier because i could leave the hinge bolted to the a pillar.
thanks for the help everyone!
Bubpletop62
Reg: 03-21-06
04-26-21 11:50 AM - Post#2818835
Glad it worked out for you. Those pins can be a bear.
Congrats!!!
Dennis Bubp
Dennis Bubp
drbubp@hotmail.com
Site Ambassador
04-26-21 06:47 PM - Post#2818856
Happy to hear it was a fairly easy solution.
1957 Cameo Carrier
Execution time: 0.117 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:17 AM
