Username Post: 65 impala fender bolt        (Topic#364953)
995jim
"5th Year" Platinum Supporting Member
995jim
Loc: Ohio
Reg: 12-17-06
04-19-21 01:43 PM - Post#2818368
Hello, Can someone tell me what size bolt and what type of nut is used to attach the bottom of the fender to the bracket underneath .Im currently using a 5/16" but not sure that it should be 3/8"
thanks jim
Attachment: bolt.jpg (33.84 KB) 5 View(s)
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
BillM89
Reg: 01-22-20
04-20-21 06:20 AM - Post#2818399
    In response to 995jim
Hello, The original bottom fender bolt is 3/8-16 and threads into a heavy duty cage nut. One of mine was completely garbed, had to cut it off. They are available from Hubbards, p/n BFBC for $6.99 a pair.
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
04-20-21 11:36 AM - Post#2818408
    In response to BillM89
inline tube has quite the selection:
https://www.inlinetube.com/collections/all/?sear ch...
Ted
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
04-20-21 11:50 AM - Post#2818413
    In response to brickwhite
brickwhite,
I just went on the site. Everything is sold out.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
Oshawa65SS
Loc: Grande Prairie AB & N...
Reg: 09-22-14
04-20-21 09:03 PM - Post#2818434
    In response to beagrizzly
If you're striking out at those other places for hardware try amkproducts.com
They have a cross reference of GM numbers to their own at the back of their PDF catalog with the catalog page the item can be found on
Ryan
Build date Dec. 21 '64 Oshawa
Rick Dorion
Rick Dorion
Loc: Accord, NY
Reg: 09-21-12
04-21-21 05:05 AM - Post#2818444
    In response to Oshawa65SS
You can probably get it at Lowe's.
1967 Belair - LM7 5.3, Autogear M23Z, Global West, C5 brakes and rims.
995jim
995jim
Loc: Ohio
Reg: 12-17-06
04-21-21 02:13 PM - Post#2818492
Is the cage nut a clip type sandwiching the bracket?
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
04-22-21 04:55 AM - Post#2818530
Google Search:
https://www.google.com/search?q=gm+fender+bo lts
or
try these..
https://www.ebay.com/itm/272600417393
https://jcaparts.com/
https://jcaparts.com/products/20pc-1946-19 80-gm-5-...
https://jcaparts.com/search?page=2&q=f ender%2A
Ted
Edited by brickwhite on 04-22-21 05:03 AM. Reason for edit: No reason given.
Oshawa65SS
Reg: 09-22-14
04-22-21 11:15 AM - Post#2818558
I get the impression he wants dead nuts on correct hardware with the original maker's mark on the head and original type of finish.
There were many sources, with many of them still available so he has to pick the maker's mark that matches his original.
The yellow zinc bolts are the most corrosion resistant but I think the assembly line used the cheaper black zinc option.
I have a tougher time determining the correct fastener finish for GM than Ford, because Ford fastener part numbers all include a finish code suffix.
I have a glossary of maker's marks to manufacturer's name in the AMK book I bought, but it's at home and I'm currently travelling.
I'll post it up when I can.
Lots of GM fender bolts etc. in this group of pages:
https://www.amkproducts.com/wp-content/uploads/Ca t...
The entire catalog:
https://www.amkproducts.com/catalogs/order/pdf-ca t...
Maker's mark images etc. but no manufacturer listing like I have to post later from my book:
The GM part number to AMK number cross reference and some images of various finishes:
Ryan
bigbowtielover
bigbowtielover
Loc: Surrey British Columbia
Reg: 09-01-13
04-25-21 08:31 AM - Post#2818743
Same bolt as the other 3 at top mounting points. J nut at bottom on the bracket. I didn't have one handy when I changed a fender on my daily driver so I made one. Took a piece of sheetmetal and bent it into shape and drilled a hole and tack welded a nut to it. Slips on like original and works. I put some anti size on it too just in case I need to get it apart in the future.
Execution time: 0.09 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:36 AM
