Username Post: Lowering, 1, 1.5, 2''?        (Topic#364920)
70BelAirHT
70BelAirHT
Loc: Qc, next to Maine Border
Reg: 06-09-03
04-15-21 04:03 PM - Post#2818109
Hi guys,
I am now in the process to convert my Bel Air with Disc brake from original parts. Now that the spindle is no more there, replace coil spring is an easy task. So why not lowering it? So, should I go 1'', 1.5'' or 2''. Jamco Suspension sells 1 and 2'' drop coil spring at 199$ a pair. CPP sells 1.5'' at 99$. Price is attractive, is 1.5'' will be enough noticeable?
Thanks for all the input/suggestion!
Mathieu Bélanger
Québec, Canada
1970 Bel Air HT 2 doors 350 Sport Coupe(frame off resto)
1970 Caprice HT 2 doors 454
2019 Dodge Grand Caravan GT
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
04-16-21 07:58 AM - Post#2818154
    In response to 70BelAirHT
Hmmm....I think I would leave it as-is. If anything, 1.5". Anything else will probably affect the ride.
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
PatwithaRat
Loc: SW Indiana melon fields.
Reg: 02-22-02
04-17-21 04:28 AM - Post#2818202
My question would be "Why lower it?"
If that floats your boat, its your car, so do it. Keep in mind that a lowered car only appeals to a small portion and I'm not one of them. Also, whenever it comes time to sell, you have a very small market.
Voted most likely to end up working at a car wash.
S10mk
Reg: 01-03-19
04-17-21 05:59 AM - Post#2818206
Sorry to thread hijack.
But what would be a good set of springs to return my car back to it's stock ride height? It still has the original springs, but they seem to be pretty soft and worn out by this point. My car is a 67 2 door sedan with a small block and a manual transmission w/o AC.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
04-17-21 12:42 PM - Post#2818222
    In response to S10mk
To each his/her own when it comes to looks. Very well may depend on choice of wheels & tires!
I'd be careful with springs vs. lowering/drop spindles however...While 65-70's have a different steering gear set up you might want to take a look at this post from the 61-64 forum regarding steering geometry:
1961-1964 Fullsize Chevys » 63 Impala Suspension Help
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
Edited by docjns1 on 04-17-21 12:44 PM. Reason for edit: No reason given.
70BelAirHT
70BelAirHT
Reg: 06-09-03
04-17-21 12:43 PM - Post#2818223
    In response to PatwithaRat
It's only for the look it gives to the car.
I know that a lot of ''older'' enthusiast won't appreciate it and I understand why.
At first, when I began the restoration process, my plan was to rebuild it as close as possible to original specs after all the comments I received about the fact that my Bel Air was rare and it would keeps his value. But before the restoration starts, my plans were quite different. Bags, 454 engine, EFI, 700r4, etc. All things I didn't do. Once I drove the car 4-5 years, plans changed again. For example, the engine, I thought that the base 350 will not be enough powerfull but well tuned, it's far enough.
So now I am in the process to upgrade for power steering, power brakes and disc brakes. I want the ride to be more ''comfortable''. I did used original and NOS parts.
Few years ago, I was talking with a Mopar enthusiast. He had a Satellite that he cloned to a Road Runner with the 440 engine, stripes, etc. I was surprise to see that he took his original car to this step. He told me something that stays in my mind, don't be slave to your car.
So, after thoses years, the value of my ''rare car'' (I know, rare doesn't mean valueable) and the comment of the Mopar guy, I think that I'll do it the way I feel it. And no offense PatwiththeRat, I asked to get hint, tip and clues about what to do and your comment is more than welcome as I read almost every posts you wrote on CT and I have great respect for you.
Thank you Pat!
Mathieu Bélanger
Québec, Canada
70BelAirHT
70BelAirHT
Reg: 06-09-03
04-17-21 12:44 PM - Post#2818224
Visit the CPP sponser web site, It's all there.
Mathieu Bélanger
Québec, Canada
70BelAirHT
70BelAirHT
Reg: 06-09-03
04-17-21 12:50 PM - Post#2818226
    In response to docjns1
Tie rods on 65-70 Fullsize is not on the same side as for the 61-64 Fullsize but good tips, thank you.
Mathieu Bélanger
Québec, Canada
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
04-19-21 08:56 AM - Post#2818352
Unless things have changed recently, the drop-spindles for 65-70 are not compatible with the factory 1969-70 disc brakes.
70BelAirHT
70BelAirHT
Reg: 06-09-03
04-20-21 05:33 AM - Post#2818393
    In response to BigDogSS
You are right and this is why I didn't want to with this option.
Mathieu Bélanger
Québec, Canada
Execution time: 0.091 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:58 AM
