Username Post: Looking for Radio Information        (Topic#364883)
blue56
blue56
Loc: LaGrange, KY
Reg: 05-24-03
04-11-21 11:39 AM - Post#2817860
While installing the RainGear wipers we had to get the radio out of the way. It never worked right so I never listened to it.
I got an original radio when I got the car a long time ago and thought maybe I would put it back in. I found the radio, hooked it to a battery and it lights up. I can't figure out how to connect it to the original speaker that I also have. There were two wires on the speaker. I figure one is ground and the other connects to the radio somewhere. The Accessories manual didn't help me much, I'm afraid. I was hoping maybe someone on here could give me guidance. It is a push button radio with five buttons and says "Airline" on the front. Both controls seem to work, but without a speaker it's hard to tell if the unit actually functions.
Attachment: Chevy_Radio_Front_opt.jpg (26.39 KB) 6 View(s)
Radio Front
Attachment: Chevy_Radio_Bottom_opt.jpg (31.11 KB) 6 View(s)
Radio bottom
You can't drink all day...
...if you don't start in the morning.
steve65
steve65
Loc: New Westminster BC
Reg: 09-25-13
04-11-21 12:40 PM - Post#2817863
    In response to blue56
Lets see what the back of the radio looks like, should be fairly simple. Not many wires on those old ones.
Steve
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
blue56
blue56
Loc: LaGrange, KY
Reg: 05-24-03
04-12-21 08:38 AM - Post#2817904
    In response to steve65
There is a red wire that goes to the inside of the unit. I hooked that to the + size of a 12 volt battery. The gray/brown wire in the picture I hooked to the negative side of the battery.
The speaker had two wires soldered to it, but the solder broke. One wire is long, the other short and both are black.
Attachment: Radio_Back_opt.jpg (24.62 KB) 7 View(s)
Attachment: Speaker_opt.jpg (26.91 KB) 4 View(s)
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
04-12-21 07:39 PM - Post#2817931
that's the original 1956 radio?
A tube "12V6GT" was bad on the radio in my '56.
It was repaired and I set this radio on my work bench and connected it to a 12 volt battery and an antenna. It played and played and played.
I went to install it and it never worked again.
It appears the audio output is from the "12V6GT" tube.
This wiring schematic is for a 1956 Buick, the radio chassis are different but the electronic are the same.
The speaker is called "SP1" in the second picture. Hopefully you can find where the wires to the speaker come from.
I do not claim to be or ever have been an electronics technician, I am not a metallurgist, I am not a spelling be champion, I am not anything I have not covered.
Attachment: RADIO5.JPG (130.93 KB) 10 View(s)
Attachment: RADIO6.JPG (128.17 KB) 7 View(s)
VC56S 2 door Sedan, 40 Years
blue56
blue56
Loc: LaGrange, KY
Reg: 05-24-03
04-13-21 09:54 AM - Post#2817958
    In response to Bad56Sedan
I can't swear that this is the original radio. It came in a box of stuff, along with the speaker and some old car club magazines that was in the trunk when I bought the car.
Thanks for the schematic. I'll see if I can make sense of it and then probably decide to get this one converted to something more modern, get a new one altogether or just install the radio delete panel that was also in that box of stuff.
swbatt
West Coast Show Support
swbatt
Reg: 03-25-01
04-14-21 01:27 AM - Post#2817993
Attachment: Page1.jpg (161.89 KB) 5 View(s)
I am struggling, can't get them into a group
Attachment: P2.jpg (348.97 KB) 4 View(s)
Attachment: P3.jpg (149.33 KB) 4 View(s)
Edited by swbatt on 04-14-21 01:30 AM. Reason for edit: No reason given.
swbatt
swbatt
Reg: 03-25-01
04-14-21 01:37 AM - Post#2817994
    In response to swbatt
Attachment: P4.jpg (334.03 KB) 4 View(s)
Attachment: P5.jpg (146.21 KB) 3 View(s)
Attachment: P6.jpg (192.87 KB) 4 View(s)
Edited by swbatt on 04-14-21 01:39 AM. Reason for edit: No reason given.
swbatt
swbatt
Reg: 03-25-01
04-14-21 01:45 AM - Post#2817995
last one
Attachment: P7.jpg (218.6 KB) 5 View(s)
last one
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
04-15-21 04:16 AM - Post#2818067
wow, great info, thanks for posting that
blue56
blue56
Loc: LaGrange, KY
Reg: 05-24-03
04-15-21 07:40 AM - Post#2818087
Amen! Thank you very much
swbatt
swbatt
Reg: 03-25-01
04-20-21 07:24 PM - Post#2818430
I've been away from here awhile. Glad this info was helpful. Took me some searching, but you guys are worth it!!! You have all been so helpful to me, it was my pleasure to give back a little bit.
Jr.
Execution time: 0.138 seconds.   Total Queries: 21   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:01 PM
