Username Post: 1927 Chevy Truck Clutch        (Topic#364870)
Dlelmp1579
Reg: 07-23-18
04-10-21 07:53 AM - Post#2817794
So, Finally got the 1927 Chevy Capital A to start consistently. However the brake light would also stay on once I pushed on the pedal. So it seemed to be an easy fix. I took the bar (brake rod from the pedal to the rear axel), off, cleaned it up and put it back - now the clutch is making noise when I press on it. When I took the Brake rod out, which is attached to the clutch pedal under the floor boards that is when the noise started w/the clutch. I am not sure if it is fine to drive like that or not.
I have adjusted the clutch pedal adjusting bolt and there is a noise (lite grinding) when the pedal is pressed. The clutch works - as I can shift it into all gears - but the noise is only there when I press the pedal, the noise stops when i let my foot off the pedal. It never made the noise before, just started when I disconnected the brake line to fix that.
Any easy suggestions? Thanks
dlelmp1579.blogspot.com - in this link are some pictures of the truck (along w/the dog). Thanks again for the help.
[image]https://dlelmp1579 .blogspot.com[/image]
Tinindian
Tinindian
Loc: Victoria, BC, Canada
Reg: 10-16-02
05-12-21 09:29 PM - Post#2819790
    In response to Dlelmp1579
If there is noise only when the clutch pedal is depressed it is almost always caused by a worn or almost worn out release bearing. The next stage is when it stops releasing the clutch altogether.
Happy Hobbying
"New Series Big Six"
6-30B Pontiac Custom Sedan
Assembled on June 6, 1930 in Regina, Saskatchewan, Canada.
Execution time: 0.183 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:58 PM
